HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
itanimuLLi
Hi, people this is my second post at overunity.com.
As far as i have wread S.M. has much to do with sound systems,
and he probale stumbled on an anomaly when he was making some kind of sound filters for Bass filtering. if you look  close to the snapshots he uses thoroids from these kind of filters, of wich he probable altered.
just a thought of my side
regards
wattsup
@itanimuLLi
You must have been reading my mind about the toroid. I was just about to post the following when you posted yours..
@all
I think we need to discuss about the center toroid cause I need some explanations.
I finished winding two coils onto my toroid of one layer of 29 awg 144 turns.
Now this particular toroid is shown in a previous post above. It was taken from a 110vac toroidal transformer which I unwound. It has about the same measurement as the toroid in the FTPU, OTPU and LTPU which is about 2" dia by 3.8" high.
I tried to see directly just by pulsing a DC on one coil and measuring on the other coil. The other coil is giving me practically nothing so I imagine that this toroid is not suitable for what I want to do.
The original transformer of the toroid had much much more windings so I imagine the core was designed to enable only so much transfer from the primary to the secondary that was 40vac.
The TPU toroids have a light color, probably white or light yellow (hard to say).
Does the color have any relevance and if so what should I be looking for in an appropriate toroid. I have a few yellow ones here that I had ordered way back during the miniTPU thread. They do not have the same sharp edge. They have more of a rounded edge. But as far as specs go, what should I look for. This is a key components that will have major relevance on the TPU operation. Also, it seems to me that such a hefty toroid core with such a slim winding must mean something that we are not understanding yet.
I think the toroid core is what is hold and increasing in something, charge, energy, field, and this is why the voltage rises gradually in the device.
If some of you could concentrate on the toroid question, maybe we could advance in that end while the rest of the device is getting cleared up.
itanimuLLi
@wattsup,
In one of the video`s he mansions of a buzzy and gyroscopic affects in hand, for me this means he`s work with some frequencies in Bass thr region 5 to 1kHz. i made some test with a ac motor of a washing machine and put some variable frequencies on the rotor. i had best performance on the lower frequencies but no overunity. once i had a high voltage shock when i was mesuring at the stator side the input voltage was just 12 volts ;D
sparks
@wattsup or should I say detective wattsup :)
Have you identified the scource of the purple light coming from underneath the open tpu.  This is the color of plazma I saw in my fluresent bulb when I dc pulsed it.  Ever notice the peculiar way sm picksup his tpus.  One level gets hot and the other one cold.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Motorcoach1
@ EM , Some time ago I did a similar design to make a super degauss for TV sets. very dangerous ! It had some strange affects at different freqs, i tried explaining this the Dr Snoswell but it it had been a while and really didn't understand it so i let it go. I did run across a blog that the university of Mexico was working on something similar and had similar results and failures. You might want to look into this. and yes my coil was the same material as your using steel banning. 4 quadrants that were sequenced around the perimeter and crossed quadrant field gave the strange results. there may be some time compression at this point and excels very fast. remember I was using it as a super degauss  do not try this !! the power factor gos up by pulling the Field out of the tube. what I did was try it from the back of the tube by the yoke and all hell broke lose and almost killed me.
