HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
poynt99
Quote from: Loner on May 20, 2008, 06:01:15 PM
It is a slightly smaller unit than what is in the TPU's, but looks to be the same style.
I have been wondering and looking at that same thing.  THIS IS the only common point in ALL the
SM tpu's,
really ???
jdurban
Quote from: Motorcoach1 on May 20, 2008, 06:39:03 PM
@ EM , Some time ago I did a similar design to make a super degauss for TV sets. very dangerous ! It had some strange affects at different freqs, i tried explaining this the Dr Snoswell but it it had been a while and really didn't understand it so i let it go. I did run across a blog that the university of Mexico was working on something similar and had similar results and failures. You might want to look into this. and yes my coil was the same material as your using steel banning. 4 quadrants that were sequenced around the perimeter and crossed quadrant field gave the strange results. there may be some time compression at this point and excels very fast. remember I was using it as a super degauss  do not try this !! the power factor gos up by pulling the Field out of the tube. what I did was try it from the back of the tube by the yoke and all hell broke lose and almost killed me.
Very interesting. I can see why use of switching or stepping coils would enhance the degaussing process. It would save the manual circling motion one has to do during degaussing and as you pull back from the CRT to conclude the process.
Any ideas connected to the T.V. repair industry can't be overlooked.
Windows has detected a mouse movement and will now reboot.
Motorcoach1
@ JD- I imagine it could as when I was doing this that was the goal. Now I feel the vacuum tube CTR and TVs are going into the sunset as we move to the digital age monitors. but the hollow tube effect might work with EM's device and it would be easy to control the ramp up runaway effects. This gets into wave guide tubes so the power is contained and manipulated. Much like my hollow core rings I was working on a while back , I posted some photos of the device and never got to wind the rest of the coils and test it.
nickle989
@em, @all,
Take a peak at the Dr. Stiffler thread, you will see some similar side effects.  EM - have you tried putting a NEON in line ... don't use a fluresent .. it is the wrong gas ... mercury.  One of the most abundent gass other then hydrogen is neon in the universe.   I have seen some very interesting scope shots from my Boyce design to Dr. Stiffler's and soon to be SM knock-off (actually EM's).  I am sure I will find some more interesting scope shots.  All that I have seen there has been some very common things on the approached tuning shots.
@ Grumpy,  have you looked at Hamel ... on what you were saying on the ambient ... I can see in my own research the devices that I have built have different performance values in different parts around me ... as I get closer to the magnetic lines of the earth.  I should have been documenting more on all instead of brain logging it.  I can tell you that I can see more energy but less stability to control it in very rocky areas vs. soily areas which seem to have less energy but more stability ... I would like to try it some stuff out in the middle of a desert as another comparison.  It is hard to replicate someone elses project to a hundred percent because of our surroundings.   I couple of years ago I when doing some PM research was probably the greatest enlightenment into how much our surroundings have cause and effect.  I have set up a triangular magnetic form pendant ... and watched it from a distance ... and waited for it to stop swaying and turning (which I had not forced)  I then walked towards it and my own body started it up again.  Very very surreal.  Anyway ... enough people around here might think I am to nutz as it is hard at times for me to put it into words.
Everything that is has already been in the future.
Grumpy
Your body has fields of energy and interacts with other fields.
        -Frank Edwards
