HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
jdurban
Quote from: wattsup on May 26, 2008, 10:24:06 AM
Guys, gather round for a minute.
SM was in audio. I know this may sound stupid, but do I ever care. (Actually I do.) lol
The way the FTPU center toroid is dimensioned is very particular.
I have not been able to find such toroids on the market. None. Yes I have been looking all over. Those center toroids are not ferrite. From my own  tests, no ferrite with so few winds would do anything to influence such a massive toroid core. They're not laminated iron and they're not iron powder either.
If it is the toroid I am thinking of it is just a catalog item that I have used a lot of over the years in switching power supplies for filtering.
The dimension issue I am talking about is more the center opening is smaller then usual toroid cores. This makes it a much thicker toroid core. Now curiously, I have seen this dimension before but not in toroids......?
Are you talking about the choke in the center? If so that is readily available.
I am now sure the center toroid core is a speaker magnet that he painted white enamel. This explains some edge shadows that are inconsistent with a factory made toroid core. Onto this he wound two field perturbation primaries.
We all know that a DC current sent into a coil produces a field that by itself does nothing, just like a speaker magnet left on a table will do nothing.  Move the magnet over a wire and you make power, except in this case you don't move the magnet, you perturb the magnet field. When you release it, it returns to where it was for free. Two... Two...... Two movements in one. You push it out, stop, it comes back. This moves the field over the collectors. So 3000 cycles out makes 3000 free cycles in. The return cycles are not a field collapse, it is simply another magnetic field movement which is additive.
DC on a coil produces a DC flux.
What's even better with two primaries is you can use @allcanadians circuit to make two movements in one pulse. All you need is a Tesla short circuit. Add that to the two free returns makes four movements with one pulse. What a deal.
Now if you have a center speaker and you have an outer coil ring making like a microphone, what do you get? Feedback. This feedback is what makes the current flow in the system. I would bet top dollar that in the FTPU spool center is a speaker coil. The speaker magnet is doing two things. It permit a speaker coil to oscillate so it can make feedback with a microphone, and it provides the field that is deflected by the two primary coils.
I can't see a microphone playing a role in this device. It would be too susceptible to ambient noise in demos where the slightest clipping would cause the mic to run out of headroom thus losing feedback.Also... this comes back to scalability. The smallest unit is the reference for testing such theories. If it can't be done on the little TPU it should be discarded.
But there's more.........
Now you choose. Which is the microphone and which is the collector, the ring or the control coil. Feedback is the best return loop. No SS components required. The junction is through the air.
One major reason SM said not to go near the tpu with a piece of metal, and he told the others to remove watches and rings, was simply because the metal would immediately stick to the magnet and give away the secret. Plus such an impact would risk ruining the coils. lol
Considering that the vast majority of jewelry items are non-ferrous materials like gold and stainless steel I would discount this SM statement as another decoy. This theory is supported by the TPU that was demonstrated on top of the stack of VHS decks. Can't get much more metallic than a steel chassis.
The center toroid mounting bracket with the two terminals on a toroid with two coils does not make sense. You would need four terminals if this was an off the shelf design, but there's only two, sooooooooooo. This is simply a bracket for terminals going to a speaker coil. He put a white padding between the bracket and the toroid magnet to protect the toroid windings. The padding may also have a dielectric issue since he places the small magnet to these terminals.
The magnet has to be in the center of the collector.
A while back I had put up a video of moving litz wires located here that shows this effect. Somewhat similar to @marco's dancing magnets.
http://www.youtube.com/watch?v=XXgL4Wf8zrQ
I know this sounds (no pun intended) like very simplistic gibber jabber, but the parts fit in so well.
I think I am now ready to make a FTPU build. I will need some help on the EE side.
@JD
I have a question.
Did SM have access to speaker components such as bulk speaker magnets, speaker coils, speaker coil terminals and terminal to coil wires, etc., or, did he have access to speakers from which he could have removed these?
Of course but Steven was working on the TPU prior to Sheric.
I am almost certain that the center toroid is the last component in the output and merely provide some load isolation and smoothing in a rather conventional manner.
When evaluating this technology always default to the simplest common denominator. Steven recently told me again that he did not know how the device worked. It just did.
By the way just as a side note Steven and I are completely back to where we were before. He understood why I had to appeal to his ego to get him to surface. It's really nice to be talking again. He is without a doubt one of the most likable and intriguing people I will ever know and I have worked with a few.
Windows has detected a mouse movement and will now reboot.
AhuraMazda
Quote from: jdurban on May 27, 2008, 01:29:01 AM
Jack,
Why don't you suggest to Steven to join this this group then we can all together be puzzled as to how the TPU works!
As a side note, he must be a very shroud business man to sell the product with out knowing how it worked.
AM
jdurban
Quote from: Loner on May 27, 2008, 03:30:39 AM
JD, please don't take this the wrong way.
The only thing I wanted to say was, if the center "Torrid" or "Choke" is an output filter, and on the
Large TPU, I understand that a comercial grade 50A fuse was blown by shorting it across the output,
then wouldn't that have melted the wires on that choke.  I'm NOT saying it wasn't an output filter,
but the amount of power that fuse would use to blow would seem to be beyond what the choke could
handle.  The resistance of that choke would be enough that the fuse would last longer than the wire on
the choke?   Now, if it were cold electricty....   Or multiple winds in parallel.....
I holding on to your statement, for the time being, but I feel there may be a grey area there.  Glad to hear
you got back with SM.  Hope that he can get a little pride out of all that his device has caused here.
Please, give him our (or at least mine) regards and wish him all the best.  After what he must have
gone through at the time, I doubt he would ever want to even hear about the happenings here, never
mind even think about being involved, but at least he should be comforted that his ideas were not
lost on the world, and the concept lives on.
Art.
Hi Art,
Actually Steven does frequent the site. Who do you think "Mercury" was?  ;D
Steven cannot participate as a result of the restriction the feds put on him. He sold the technology prior to the sale to U.E.C. This explains why Steven never told Lindsay enough to violate the order.
All the best,
Jack
aleks
Quote from: wattsup on May 27, 2008, 12:18:56 AMOK here it is wound.
Well, it does not look like a "normal" coil design. Magnets are rarely used as core, no? I would speculate that central toroid is just a pure electromagnet winding, no permanent magnets are necessary. I had an unrelated idea in the past, of an obvious electro-dynamic speaker: the one which bends ferromagnetic metal by means of electromagnet's varying force. This is a highly non-conventional design (compare it to conventional speaker drivers), but it may be what is going on in the TPU (if the central toroid is an electromagnet).
Electromagnet simply re-produces mic's signal "with gain".
And, BTW, only in acoustic terms I would justify changing of "delay time" by cutting wire in length. If delay is non-acoustic, wire length won't make any serious difference if it's not an inductive element.
plengo
Thank you Jack Durban for your efforts and thanks Steven Marks for this amazing device.
No offence intended to anyone here. I am very puzzled how this whole story is becoming very close to soap operas in Brasil. We have an inventor, a scientist and a group of intelectuals in one forum, We have the device in video and lots of theories. All these puzzles could easily be solved by simple words of the creator Steven Marks which according to Jack Durban is here already with us, reading and seeing all this drama.
Why dont we get this to the end NOW, there is no better time than NOW. It would be one post from Steven or Jack after talking to each other and that would be the end of this whole problem, why that is not happening???? UEC, FBI, CIA what is the point? It sounds just like a soap opera a big lie.
The device is in video, the inventor is here BUT NO EXPLANTIONS, no help really, just a ghost trail, a duck hunt but no ducks. Can not we get this thing explained fast and easy?
Fausto.
