HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
poynt99
well, after downloading the torrent the second time, I got the same message from winrar.
it turns out that it blew the little mind of my "older" version of winrar when it saw a 3.5Gb zip file! ....time to upgrade.
thanks for the 7-zip tip, it worked well, and is a nice clean simple program. now I hope Nero knows what to do with all these VOB etc. files to make the DVD.
hartiberlin
Quote from: rensseak on April 15, 2008, 02:49:24 AM
@Jdo300
could download all files of part 2 except .z04 and .z07. Something is wrong there, it will not start with downloading. Pleasae could you check it?
thanks a lot
Norbert
It takes a while until these 2 parts will come up in the download in Mediafire server.
I had the same issue.
Just wait about 2 to 3 minutes and then the download will come up.
Did anybody put up yet the remeining 3 VOB files there or
to other download servers like rapidshare.de or megaupload.com ?
Many thanks.
aleks
hartiberlin
@Wattsup,
many thanks for your PDF about the OpenTPU,
but I don?t think you have the coils right.
The output coil must be just a single wire turn loop of the white wire
or maybe just a few turns like EMdevices have drawn here:
(Probably without the cap.)
Over this output coil there are just wound 4 control coils.
These 4 control coils must have been wound this way, so that a positive feedback
from the output coil must feedback so much power back into them,
so they start oscillating.
Maybe there is a phase shift network with some big caps, so 2 coils always are in 90 degrees
phase shift and thus the magnetic field of the coils keeps oscillating in a circle
and produce this gyroscopic sensation.
Thus these 4 control coils of the OpenTPU keep oscillating in a circle and due to positive
feedback from the single output coil, this magnet field is spinning up in frequency to then
about 5 to 6 Khz.
The output coil then has only DC on it with some 5 to 6 Khz "hash" ( overlayed AC) on it.
It is very logical, that the single output coil just has a DC Voltage on it with some "hash"
as the magnetic rotating fields like a vortex whirlwind just push the electrons inside
the single output coil into one direction all the time.
Thus it has just a DC voltage on it. ( with some 5 to 6 Khz AC superimposed due to the
moving rotating  magnetic vortex)
This is all very logical and due to the calculation I did earlier about the
internal resistance of the output coil having to be equal or less than 50 milliOhms,
the wire of the output coil can not be very long, so it is probably just a single
turn or maybe 2 to 3 turns of wire and it is probably just this seen white wire
which runs hidden under the 4 control coils.
I also think, that the smaller and bigger TPUs might be working on a slightly
modified principle, as in the big 17 inch TPU there are probably more turns
of output coil wire and much bigger diameter sizes and the rotating vortex
frequencies that control there the control coils might be controlled by the 2
switches and the 1 potentiometer that can be seen outside this big 17 inch TPU.
All in all, if one understands how to get this positive feedback to work,
so that you can run the 4 control coils on their own freedback energy
in a rotating fashion , feeded probably
from the output coil, you are able to build a working TPU.
It is just the positive feedback that we have to find out, how this works.
Regards, Stefan.
EMdevices
I have no doubts that the device is very very simpleÃ,  :)
I finished dowloading the whole DVD,Ã,  and viewed all the VOB files with NERO installed on my computer.
BUT
I'm a bit disipointed,Ã,   I found out VOB 4 and 5 hardly have anything on them, (5 has nothing whatsoever)Ã,  I watched just static on the screen.
Then VOB 3 had a segment of the large TPU rewinded OVER AND OVER AND OVER AND OVER AND OVER ........and over and over again,Ã,  it's so freaking annoying.
I guess the original was being studiedÃ,  closely and paused to see the detail on the large TPU.Ã,
I just hope there's better video once Jack fixes the hi-8 player
We would benefit greatly from the video where Steven demonstrates a TV working and towards the end of that he explains how it works, but the audio was muted later by editing.Ã,
Ok, VOB 1 and VOB2 had the most relevant info,Ã,  they show the video we use to call the UEC video, and the First TPU and the OPEN TPUÃ,  (two ring one)
So, somebody knowledgable can edit this DVD and take out all that dead time, and we can have a small file size.Ã,  I estimate it will drop in size from 3.5 GBytes to perhapsÃ,  1 GBytes or less.
I'll keep my computer going to seed for the other for about a week or so, so hurry up and download.
EM
P.S.   Jack mentioned the French origin for the technology,  I wonder if perhaps Steven was browsing the JNLabs website and saw something there?
