HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
0 Members and 19 Guests are viewing this topic.
jdurban
Quote from: -[marco]- on April 20, 2008, 01:41:10 AM
Quote from: jdurban on April 20, 2008, 12:26:33 AM
You must understand that SM was and is a B.S. artist, a con man. I know some of you can't fathom that but it is fact. I know first hand. He will lie when there's no reason to lie. He makes claims that anyone can prove false. Case in point: his reference to having hundreds of patents and one had over 750 pages. All 100% B.S. He has one utility patent on an unproven 3D sound theory and 5 design patents on speaker aesthetics. The sound patent is a real patent. The design patents are worthless.
Jack,
What is the chance that the devices themselfs were a fake?
Suppose he would connect them to a charger at the end of the day to charge them up for next show..
There are many ways to fake what is seen on the video tapes.
I can build something that looks exactly the same with a series of nicad's inside and power bulbs for a short period of time.
Is it possible that he hired you to come up with something that would work just because his was a fake??
If Steven was that master of BS and the con man, then i think the device itself could be fake too because he was just in for the money...
Many people who work on something for a long time fake it when they cannot get it done.
M.
It was real and many others far smarter than I saw it too. I had already seen my share of quacks so I did not go into this prepared for seeing a real free energy device. I was just curious and it paid off.
I am intimately familiar with battery chemistries as many of my designs rely upon them and at that time there were no readily available high watt density cells around like Lithium Ion or Lithium Poly Ion. And consider the absolute nightmare of tearing down these units regularly to swap out cells!
Your reference to Nicads...Nicads have a very low watt density and would have been a very poor candidate. The ideal cell of choice would have been the good ol' AA cell but at 1.5 v per cell...well you do the math.
And much more importantly the SM device is not the only device out there that worked.
Windows has detected a mouse movement and will now reboot.
turbo
Quote from: jdurban on April 20, 2008, 02:19:04 AM
Well i have done the math long ago and it actually surpised me to see what can be done.
Especially when we take in account the 20 minute breakdown.
At first i was also thinking this cannot be faked by using batteries but now i know it can.
As for the low watt nicad density it is possible to switch like 10 cells in series on top of another 10 cells in series so both packs in parallel giving 12 volts which can be stepped up to higher voltages to power regular bulbs.
I have tried this and i found out it was possible to pull out 300 Watts of power at 230 Volts on off for a couple of minutes.
When using LI-ION packs this was even easier to do with less cells but we all know these cells were not available at the time the vids were made.
M.
turbo
If we want to power a bulb 60 Watts off one cell 1,5 Volts the amperage has to be 40 Amps.
P=UxI  60=1,5x40
BUT if we use 10 cells?? in series or parallel for example 10x1,5 Volts =15 Volts
P=UxI  60=15x4
Now the amperage only has to be 4 Amps.
So if each cell is capable of delivering 2500mA the bulb will lite up fine.
This dirty calculation is still on the tight side so we switch 10 cells parallel to 10 cells etc. and now each cell only needs to deliver 2500/2=1250mA which can be done.
I have tried many cells in series to get to greater voltage levels and we need alot of batteries to get to higher voltage.
If we want to achieve let's say 100 Volts we need 100/1,5= 66 cells
I have also tried with inverter boards which take a 12 Volt supply and convert it to 230 Volts.
This technique is used in computer backup supply's and in truck/car/camper vehichels.
I was able to power quite some bulbs off simple portable drill NICD battery packs.
I even powerd a television set for quite some time out of this pack.
It was a nice experiment because i called up some friends and i took the television set along with the inverter to a park nearby.
We were watching television in the park and my friends were trying to figure out how the set could operate without a mains supply.
I am not saying Stevens things work on batteries ,in fact i hope they are for real.
But i just want you all to know this CAN be done with batteries.
M.
aleks
Since SM on the video notes that his TPU "buzzes" even being disconnected, this suggests that no batteries are in use. Batteries may buzz or heat up only being short-circuited. In fact, I do not see a reason for TPU to buzz if it uses batteries alone.
turbo
I do see a reason for it to buzz if it is used to step up the voltage.
In fact every transformer buzzes due to the magnetostriction effect anybody knows this.
M.
