Thanks to ALL for your help!!
SERLS GIFT TO YOU ALL. FREE POWER AS YET UNTAPPED
Started by samzoelisa, April 15, 2008, 07:42:07 AM
samzoelisa
hi all
well we figure that as we are taking away drag by allowing free airflow from front to back we must be gaining ?
as instead of the air hitting the front of vehicle it is being allowed to do a little work and then exit under the vehicle .
well were gonna make a test vehile , our own estate wagon , and well film it all for you . as we often state we dont believe in cant ..but can ................. i look at it this way if a wind is hitting a solid plate ok you have drag but if say it is made to revolve an impeller then it is not producing as much drag  and is being set free under the auto.
best wishes
keith
nothing is impossible , forget the laws of physica as they were thought up by ill informed idiots 300 years ago .to go forward we must forget the past and if we can think of it we can and will make it .
samzoelisa
Dear Megger man
serl is short for   SINCLAIR ENERGY RESEARCH LIMITED  uk registereed company
MATH MATHEMATICS WHATEVER AS LONG AS ITS UNDERSTOOD ,LOL
regards
KEITH
MeggerMan
@Sam,
Oopps, should have read your first post a bit more carefully, looks like I put my foot in it, sorry.
If you have a unique way of extracting H2 from water then go for it. Even small amounts of hydrogen in an ICE will help but you need to play with the timing unless the engine can adjust its own MAP.
I look forward to your results.
Rob
samzoelisa
Dear Tak
Interesting point which i think all people are thinking about
well were gonna make an experiment quite soon with two generators on front of the car and see what happens , imm tottally confident that i will be right and that all calculations are correct ,
it has already been done in a different instance i believe in austrialia but there to power an electric car ,
so im pretty confident the same idea will function for our slightly differnet use ,
well pop a film of the test on you tube at ouer normal place ,if you go to science and technology and type in easy hydrogen production we should pop up
regards
keith
samzoelisa
dear megger man
thats ok ! yes we have a compterised ctroen so expect probs with it unless the computer speaks english ...lol    from what we know the timing will have to be advanced up to 20 degrees , this is our one unknown factor .
have fun
regards keith
