Alex's MT Combination
Started by Alexioco, April 17, 2008, 04:57:41 PM
helmut
Quote from: Alexioco on May 04, 2008, 08:40:14 AM
Ok I have made another improvement to my wheel, I have added another wheel, I belive my wheel to be complete now, tell me if you agree that my wheel is improved
Hi Alex
This might be a amplifier to improofe a swing to a pendulum.
But if you imagine,that the wheel will turn 360 Degrees???
Please print out a drawing and cut the wheel out,than take the paper wheel and turn it i your hands.
helmut
Alexioco
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Alexioco
Well I thought the above wheel would be the best one as not only do the weights A and C do the lifting, but they also take an outer position on the descending side...
Alexioco
Quote from: P-Motion on May 05, 2008, 11:44:35 AM
Quote from: Alexioco on May 05, 2008, 10:31:14 AM
  Sorry, was thinking the rod went all the way past the axle.
You are right, it might be the best one to try. One thing I like
about it is it's simplicity. If it works, you will know why. And if it doesn't,
shouldn't take much to figure what modification you need to make.
That is one thing about it, if you are used to working with a scale
of 5 and 10 ounces, might be easy enough for you to try a build.
A lot of it does come back to what a person is comfortable working with.
Ok, I have one final question which you could help me answer :)
About this very new wheel above, even though weight A sticks out further its got to go past the bottom enough for weight B to make it to the bottom and weight D to make it to the top so they can lift, I can only think that momentum will achieve this, would you agree?
Once this is sorted, I will make my wheel...
AB Hammer
@ Alex
There is one thing to remember. The amount of travel has to compliment in a form of timing to the speed drop or it will most likely keel and balance downward.
PS take a look at your sight.
Alan
