Alex's MT Combination
Started by Alexioco, April 17, 2008, 04:57:41 PM
Alexioco
Ok I have just confirmed to myself that my wheel will work, I don?t want to say it will 100% because it is not built but this is what I have to say about my new invention which I have presented to you all.
I tested the lever mechanism (as you saw in the video) to see if the weights were capable of lifting the prime weights in order to cause rotation, and the result was good, the lever mechanism as you see in my pictures do indeed work.
Secondly, I cut a cardboard wheel out and stuck weights in the positions they take in order to cause movement, I let the wheel go and the weights do indeed move the wheel far enough in order for the process to repeat, the wheel only has to move so much and the entire mechanism starts again, also its so effective that the wheel turns more than enough for the process to repeat, all I need to do now is build this wheel, then film it and post it here as proof of a perpetual motion wheel, probably the same as Besslers as my wheel is purely from his wheels...
If my wheel for some unknown reason does not work, then hence we have something to learn from this thing?
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
fletcher
Treat every build & test as an opportunity to learn something Alex & you will never be dissappointed because the learning always goes on.
Alexioco
I would agree, if my wheel works or not, either way, there is something to be learnt from this build weather it is simple or complicated..
Alexioco
Ok my wheel is being built as we speak  ;D
Edit: My Wheel has been built, all four levers are attached, just got to connect them so they become pair of pairs, then I need to get the weights and I'm done, the hard parts are over  8)
Sprocket
Shall I initiate the drum-roll? :)
Really looking forward to seeing what happens...
