Feynman makes a Bedini Motor
Started by Feynman, April 18, 2008, 12:41:22 AM
WilbyInebriated
Quote from: willitwork on July 19, 2008, 01:09:01 AM
Ok, now we are getting somewhere. This is right back to my initial post.
Completely flatten the target - (charging) battery - (Battery-A)
Completely charge the source battery (Battery-B).
Start the Bedini.
Charge the target battery (Battery-A) up without touching the source battery  (Battery-B). Don't put any external charge in either battery ever.
If the Bedini is working as you suggest you have charged a battery  (Battery-A) with leading pulse, aetheric etc energy. Congratulations.
Now Put the charged battery (Battery-A) in the source position.
Flatten the battery that was the source battery  (Battery-B).
Charge it with the Bedini.
My original post did not call for the full discharge of the target battery (Battery-A) , if you wish the light bulb approach mentioned earlier will work.
To complete this you will need to demonstrate that you can keep at least one battery fully charged no matter how many times you swap them.
I am letting you off easy because most Bedini evangelists would seem to claim that they can keep both batteries fully charged.
If the Bedini is just a pulse charger you will not be able to fully charge the target battery and after you swap the two out, the system will run down to a miserable grinding halt.
PS, I worked with early Lead Acid batteries in two way systems in the seventies. Back then we used pulse systems to rejuvenate old lead acid and early dry rechargeables regularly.
NB A battery may come up to voltage but that does not mean it is fully charged or functioning to capacity. Earlier suggestions that a Bedini system actually destroy batteries may be completely correct. Pulse rejuvanation will occaisionally give a battery a new lease of life.
Another Prediction: Assuming both batteries are identical you will never be able to fully charge  (Battery-A) from  (Battery-B) in a Bedini circuit.
"Charge the target battery (Battery-A) up without touching the source battery  (Battery-B). Don't put any external charge in either battery ever." this is a contradiction.
your test is garbage, this was explained to you right after you posted it. i remember smirking...
PS i don't care what you did on who... you didn't replicate the sg circuit, you changed it how you saw fit and cried when it didn't work. i'm not gonna let you off easy, how many times do i have to say this?
another prediction: you will continue to talk out your ass instead of actually applying science and replicating
PSS we are still highly interested to see your $10 dollar pulse charger that is powered by the battery that it is charging...
willitwork
PS i don't care what you did on who... you didn't replicate the sg circuit, you changed it how you saw fit and cried when it didn't work. i'm not gonna let you off easy, how many times do i have to say this? another prediction: you will continue to talk out your ass instead of actually applying science and replicating
No contradiction intended. By external charge I meant once you start this test don't put either battery on a traditional charger. (if you that is still not clear I meant - don't cheat)
Just take your Bedini which has two identical batteries in it. One is driving the motor (Battery-B) and one is being charged (Battery-A). Then discharge (Battery-A) completely and let  (Battery-B) charge it. Then swap them.
Who knows, you may be the first person ever to fully charge an identical battery with a Bedini.
I'm not asking much
WilbyInebriated
if you're not asking much, then do it yourself.   ::)
hey what do you know, my prediction was correct.
PS still waiting on that $10 dollar pulse charger that is powered by the battery that it is charging...
willitwork
That was quick, how did the test go?
WilbyInebriated
Quote from: willitwork on July 19, 2008, 01:42:22 AM
are you mental? how did what test go? your garbage test? as i told you, if it's not asking much then do it yourself.
