Roll on the 20th June
0 Members and 94 Guests are viewing this topic.
Rolo
Quote from: sigmaX on May 28, 2008, 06:51:59 PM
In short, he takes hot air from the end of a heater / turbine, thru a hose, and reinjects it in the air intake, stating that this gives far more hot air.
Yes, but of course: if you reinject already heated air into the intake, you will have more heated air at the end. BUT A LOWER FLOW BECAUSE PART OF THE OUTPUT FLOW REROUTED INTO THE INTAKE AGAIN. But then he says that he breaks the "law" that states that  ?It is not possible at a set wattage and set voltage to get more heat out without more power in? ... And I should add "WHILE MANTAINING THE SAME AIR FLOW"
His invention does not mantain the same AIR FLOW. the real air flow output is less, because part of such airflow goes back into the heat turbine. He gets less air, but hotter. Something that could also be somewhat accomplished by closing a bit the air intake.
Hi SigmaX
This is how I view the Archers Loop device.
Take a heater tube that holds 100 litres of air.  Flow air into the inlet at 100 litres/sec. Air will exit also at 100 litres/sec.
Add the loop tube as described from inside the exit looping to just inside the input holding say 10 litres of air.  Fill both the heater tube and the loop tube with air (110 litres).
Now flow 100 litres/sec at the inlet and tell me how much air is exiting.
With air looping through the loop, this 10 litres/sec gets heated twice thus increasing the output temperature for the same flow rate for the same energy input.
Rolo
ramset
Spinner so post a couple links  Chet
Thanks Grandma
spinner
Quote from: ramset on May 28, 2008, 08:08:07 PM
Hmm, better not...
I don't want to spoil the party on 20th.
"Ex nihilo nihil"
Chad
@spinner
Ok if the idea has been done a thousand times and is proven to be a waste of time why are people so worried about people building a version of his device?, i mean what harm will come of building something that wont work, at the very least it would show another way of how it wont work, it may even spark new ideas wich may eventualy lead to an OU device.
With "Mental Masturbation"........the idea will eventualy cum  :D
ramset
Spinner it wasn't a joke  im serious   post one link  why are you really here?  Chet
Thanks Grandma
