Roll on the 20th June
0 Members and 27 Guests are viewing this topic.
street_creep
Quote from: infringer on May 31, 2008, 01:49:26 PM
Hrmmm I really hate store hours around here they are never open still havent found a local place for magnets though.
Don't know where you live but have /had same issue here . only place i could find for a quick fix of magnets is a store called Lee Valley Tools. Not bad assortment . Make sure you ask someone there as they are not kept out front. I have others coming from elsewhere.
Just a thought
hartiberlin
Quote from: Evg on May 31, 2008, 09:30:57 PM
I belief it is something like this.
Okay, lets try to explain it with this graphics:
The green weight No.2 is 5.25Kg and the pink weight No.1 is also 5.25 Kg.
Now the green weight is up and the left dish is in the water.
So that the green weight could lift the water, the watermust not weight more than
1 Kg ( I have tested this with WM2D).
So the green 5.25 Kg weight goes down and lifts the left dish with 1Kg water up.
The green weight goes down during this cycle 90 cm.
Okay, this was partial step 1 of the cycle.
Now to partial step 2:
The pink weight No.1 with 5.25 Kg can also only move 90cm down to be compatibe
with green Weight No.2.
So there must be a pulley gear of 5:1 to lift the right dish up by 4.5 Meters ( 90cm x 5 = 4.5Meters)
So as the pink weight No.1 also weights 5.25 Kg, it can only lift 5.25 kg / 5 = 1.05 Kg water.
Now the right dish with 1.05 Kg water is lifted up as the left weigt No.1 goes down
and when it tips versus the Tipping bar, it moves all its water from the right dish to the left dish
and the catching hooks connect both weights together when they are down.
Now we have at the left side of the fulcrum a combined weight of 10.5 Kg and
at the right side in the left dish a weight of 2.05 Kg Water...
But this is still too low weight of the water to lift the 10.5 Kg left combined weight,
as only 2.1 Kg water will begin to lift it up again.....
This way it will not work...
So anyother idea how this sketch drawing from Archer was mean to be working ??
onesnzeros
Quote from: hartiberlin on May 31, 2008, 07:20:38 PM
I can hardly read his handdrawing:
It says to me:
Make sure main weight falls before ??!? empties on extension
Catch Hooks must hinge
No.2 Total weights split side by side,
keep in guides for ??!? fall
Can anybody fix in the missing words ?
I would love to help you fill in the missing words:   "ARCHER is a FUCKING MORON!"
Hope this helps.
Respectfully,
onesnzeros
fastbreeder
Quote from: The Eskimo Quinn on May 30, 2008, 10:07:40 PM
...you complete moron, ... you stupid stupid clown waste of space human being ... you idiodotic clown, ... the dumbest human that ever ever lived ... losy idiot ... clown ... loser... loser people... newtonian moron.... clown ...what a moron...truly the dumbest person i have ever come in conatct with.
Well, you've cut out the obscenities, so that's progress.  Still chock-full of ad hominem attacks...  :-\
In none of the diagrams I've seen so far has there been information on what will trigger and power the electromagnet.  You'd have to have a physical contact switch to trigger the field just when a lever arm passes it, but where will the power for the electromagnet come from?  In order to be an over-unity device, you'd have to have a generator powered by rotation of the wheel itself.  The constant rotation would produce A/C power in a more-or-less steady output, but you need power spikes to pulse the electromagnet, which means you've got to add some kind of capacitive circuit with a voltage rectifier to reform the energy produced to a the power profile you'd need.
You'll probably call me an idiodotic newtonian moronic clown on a bike, but I recognize that if the electromagnet is externally powered, it's not a closed system, and can't be called PM/OU.
infringer
I went on a local hunt today for parts for my gravity wheel...
This is as far as I am physically able to get locally...
I will need to do some thinking before I order by the way my bearing is press fit into the wood currently I will have to reinforce the press fit with a couple of bolts and locknuts... ::)
alternatively i shall update my webpage but it will be a slow work in progress dunno if I myself will beat the 20th of june but anyhow...
http://infringer.110mb.com is my website currently.
Basically what I have is an enclosed bearing press fitted at dead center...
Let me tell you dead center was a ball of fun to find as you can see by all the markings on the wheel...
Then I have a tent repair kit for my rods... A bit down the road I will be getting PVC and trying to achive a same basic design as dusty has displayed on youtube not to doubt any other designs but this one seems rather straight fwd for me...
Also magnets of course man this thing is going to wind up an expensive project the bearring alone costed like 17bux...
Anyhow onwards and upwards.
-infringer-
EDIT:
To the clowns on unicycles trying to eat hotdogs without getting mustard on there shirts...
While it may not be a closed system if it uses electromagnets let me tell you that this would greatly reduce the amount of gas you would have to use in your generator...
I would imagine if you have the electromags check for the lowest possible rpms then kick on you could infact generate more power with say like 75% less fuel... Or use a small windturbine and solar array to give small batteries power...
The point is in conjunction with another mini scaled renewable or two this may generate enough power for justification of a smart design...
No matter how much you bash archer he does seem to have a lot of interesting ideas weather they are true OU or just super effician3 and efficiantcy we have not yet seen before may be accomplished through his devices...
Let us take into account that windturbines over a certian hieght are not allowed in many places as well...
And the money it would cost to build a windturbine or solar array in large scale would be phenominal!!! Anyone with half a brain could build small scale and use these to power the device which would in provide excess power out !!! Or they could be commercially manufactured in this manner as well...
This is our problem with energy generation we fail to see that we could provide little power everyonce in a while and achive more power output then put into the system. Or even as I said with no cost!
Watch dusty's wheel on youtube you can see it almost working as it is once the weights are added I hope to see the results...
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
