Roll on the 20th June
Slavo
dont listen to discouraging posts,
so what you will feel fucken guilty for believing in overunity???
gimme a break, fuck off all idiots who discourage
they are real pussies, they dont want to risk it cuz theyre scared of ridicule
sevich
Quote from: Slavo on June 01, 2008, 09:09:30 AM
More like I'll feel guilty believing in a load of SHIT from Archer before he proves it to me!
Anyway Slavo, how are things in Serbia mate ?  ;D
Chad
Quote from: sevich on June 01, 2008, 08:50:46 AM
You see.......this may be just it
All pro-Archer true believers are recklessly betting Russian roulette ! ......If it so turns out Archer is a lier (wrong)  by the 20th of June 2008. Then I'm afraid all those exposed may end up feeling extremely depressed and even worse, may even de-register from "overunity.com" with a feeling of extreme guilt, stress, disgrace and even shame. As opposed to the rest of those those that have taken a normal, natural, neutral and negative view.
The bottom line is this : ...... How can you believe in a person before he proves it ???      ..........(Jesus excluded)  ;D
So then...how many "Eskimo Quinn" supporters were there ? ? ?  ;D :D  ;D :D  ;D
You have got to be kidding, why would somebody be feeling, guilt, disgrace, shame along with the rest of the symptoms you describe?, if it doesnt work it doesnt work its as simple as that!.
Playing russian roulette?... will there head explode if it doesnt work?, no it wont.. at worst people will just move on to other projects and ideas.
Trying to embarress people into not listening to archers ideas is just about as low as you can get, you take away the freedom of thought and what are you left with...a forum full of drones.
People keep making the assumption archer is mad because he has an idea and believes it will work, well that makes abbout everybody on here just as mad then doesnt it, were all hear because we believe in the idea of OU.
So who is realy mad?, a person who is said to be "mad" arguing with a gang of "Sane" people... or a gang of so called "sane" people arguing with a "mad" man  :D
If you look at Nikola Tesla you could have said he was mad having all those hallucinations etc, but he wasnt mad..was he?.
lets relax see what happens on the 20th
Chad.
noonespecial
Quote from: hartiberlin on May 31, 2008, 10:49:54 PM
This way it will not work...
So any other idea how this sketch drawing from Archer was mean to be working ??
Hi Stephan,
I have what I believe is a similar design that I can present later today that may help explain.  I have to go out this morning.
onesnzeros
Quote from: hartiberlin on May 31, 2008, 10:26:11 PM
And what does mean in Archer?s writing:
-        return cost = 4.55kg tested with pulley weight under beam
Where was this measured and where does this weight come from ?
Can somebody explain it in more detail please ?
Many thanks.
Well first off if you review his math relating to the diagram, you will see that ARCHER is incapable of using math to verify any concept and a result, his numbers lead him to believe that he has extra power. Or more specifically, lead others to believe he is a genius. This is probably his real motivation.
This is his thinking quoted from another post.
The beam at the extended end is 6 metres from the pivot, and the short end is 1.2 metres
from the pivot and exact 5 to 1 measurement.
0.75 lift distance heavy end
6 metres x 0.75 = 4.5 metres travel  distance light end
Notice that he multiplied the length of the long side by the vertical displacement on the left side to determine the vertical displacement on the right. This is incorrect.
The true distance is 4.77m vertical displacement on the right, calculated from scale drawing in autocad.
So the available work on the right becomes 1.2kg x 4.77m=5.73kgm
on the heavy side: 10.5kg x .75m=7.87kgm
ARCHER states that there is 7.8kgm gained from the fall of that weight through .75m. This is true however, there is one thing missing ARCHER, how can you lift a 10.5kg weight through .75m in the first place with only 5.73kgm worth of available work on the right side?
Answer: you can't.
Onesnzeros
