Roll on the 20th June
0 Members and 147 Guests are viewing this topic.
ramset
FELLOWS I know many here think Archer a trickster or worse    but this design he is working on know   [or finished already]  is a TOY in his words    a rendering of the one he has already built [with changes] this will/does work   How much power ? we shall see  but be careful what you post on this   you may regret it  Chet
Thanks Grandma
LarryC
Quote from: Rusty_Springs on June 17, 2008, 06:36:15 PM
Sorry Larry I can't see what this test is proving, for 1 your using different size magnets which means different strengths and ofcause you double the distance a magnet moves if it repels at one end and attracts at the other.
There is no wall showing because your not comming in from the side so your not seeing how the rods will truely react, again I can't see what your trying to show with this experiment.
Sorry for the confusion. There is only one small size neo magnet being used on the end of each bar under the electrical tape. It is the small silver rectangular piece shown on the ruler and is  2 X 6 X 12 MM. The only different sizes are the steel lamination bars. First, second and third bar as discussed in the 3 Test.
Coming in from the side makes no difference. This is a simple test, try it and learn. The wall will be half the strength of the two magnets which moved the rod.
Regards, Larry
purepower
Quote from: dirt diggler on June 17, 2008, 07:19:41 PM
PurePower,
yes, yes, we all know how you will take one's words and make them right for you, but wrong for the origional writer.
[\quote]
Funny you should say this, considereing you took Newton's words (original writer of e&o) and made them right for you but wrong for him!
I will conduct an experiment when I am home. Mathematically, the results should be the same. However, in repulsion, the field lines deflect one another to skew angles (destructive), lowering the total force available that we get in attraction when the field lines are adjacent (constructive). But the physical properties of the magnets themselves (electron spin) tells you the force should be the same regardless of orientation. Again, it all comes down to electron spin and the collaboration of the field lines.
-PurePower
PS Exx, I'll post the equation when I get home, too hard to type on my phone...
purepower
Quote from: ramset on June 17, 2008, 07:37:31 PM
Hmm, on Archer's site he said it was simmilar to his "car motor" version...
So is it powerful enough to power a car of is it a toy? Those dont seem to corrilate well...
chrisC
Quote from: Evg on June 17, 2008, 07:30:13 PM
Archer posted his 18 June videos early today
Sure enough! Archer, the suspense is killing some of us! I hope the nay sayers aren't pissing in their pants ....
Go Archer Go!
cheers
chrisC
