Roll on the 20th June
0 Members and 47 Guests are viewing this topic.
tekylife
Quote from: BATMAN on June 18, 2008, 10:21:04 AM
Here is QUINNS GRAVITY WHEEL one more time for all.
Thanks BATMAN!
Will you update it to the new specifications ?
From your earlier post it looks like you built it. Any suggestion regarding materials needed to bring an industrial grade one ? That way we can find out the price of a wheel capable of powering your lab for example.
Thanks again!
sierraloewe
that's a really nice drawing-
but I'm missing a plan for dealing with the centrifugal forces- which are going to move the rods to the outside, away from the optimal postion, between 6:00 and 12:00.  We're going to need magnets nearly all the way around!
sierraloewe
actually, considering that, maybe you only *need* magnets between 6:00 and 12:00.  the spinning will want to force the rods to the outside all by itself.
gwhy!
Quote from: sm0ky2 on June 18, 2008, 12:08:51 AM
i kept hoping you would figure out a way to incorporate that effect into this wheel, but it seems like you are not interested enough in it to even give it a second thought...
i played around with some things, but all i got was a "booster" Tri-Force to help break the "wall" of the repelling magnets, but after playing around with it, i found that the "roller-bar" gets in the way of the repell effect. so alas.....  Archer and Tri-Force may not be compatible..?? or i may jst not see quite how it could be done..
Hi sm0ky2 and Graham
  I have also looked at the possibility of using the tri-gate on archers wheel and so far all the test I have tried has been positive as long as they are set up correctly. I think there is a very big chance that it will make the wheel a lot more efficient and the combination of wheel and tri-gate defo will be compatible from where I'm standing  :) .
Hhx
Hi all
@Archer
Thank you for your work and effort, when sharing them you have demonstrated which is the true road and the spirit of the free energy.
If it works or it doesn't work before or after June 20, this doesn't really care. The important thing is the ideas and the shared knowledge.
I prefer their explanations difficult to understand for me for my low english level before the brilliant patents lacks of data and very difficult or impossible of replicate. It is noticed that you are a very hard-working person, although the methodology is a little 'different.'
Thank you Archer, good work and Happy Birthday for the 20 ;)
Regards, Hhx
