Roll on the 20th June
0 Members and 57 Guests are viewing this topic.
exxcomm0n
Quote from: Evg on June 22, 2008, 05:15:09 PM
Writing this without too much thought given.
Why is it presumed that free energy is usually a vertical contraption instead of a horizontal wheel? (Unless you planning a gravity machine)
It don't have to, but it's the only way to get benefit from rod shift.
Hell, when Archer "broke the news" about the external weight breaking the wall, i thought experimenters would have a field day with those magnetic spiral motors I've seen a lot of on the Tube.
Seemed like the perfect solution for that wall.
Maybe you have to make an outer rolling assembly, but otherwise I couldn't see it hurting. ;)
Anyone got a spiral mag motor recipe????
:D
When I stop learning, plant me.
I'm already of less use than a tree.
Rusty_Springs
Hi Evg
Your right but I think Exx still wants to use gravity, also if you can get a system to move both horizontally and vertically wouldn't that be a better system?
Take Care Evg
Graham
spinner
Quote from: Fred Flintstone on June 22, 2008, 02:45:43 PM
@BATMAN
You have presented us with clues that you have some sort of free energy device. What is the deal?  Why do you want to start playing another game like Archer? This is very silly and childish. If you have a free energy device that works, why not just tell us what it is and what it does? Patent it if you want. Hold out details if you want. But at least tell us what it can do?  There are millions of people that are waiting for a solution to the energy crisis. Each day that is wasted playing games allows more suffering. Leave Batgirl alone for a few minutes and post your videos.
Freddy
Hey, Flintstone!
Leave Batman in his cave, he is probably busy enough with his BatGirl... Or his Batman comics books...
Looking at his controversial posts, I could say he's just another 'FE wannabe'... The data (power demands of transportation vehicles he presented are from late sixties, before the first oil crisis in 70's), also the blurry photos he has shown speaks for themselves...
(Although his CAD pictures of a Sword of God are very good...)
Of course, it's just my "skeptic" evaluation. I hope he'll prove me wrong, but the device we saw looks like a giant dynamo.... With driving pulleys(??), a half ton of magnets, etc...
My personal observation is (when comes to the FE claims):
The probability of a real FE device is inversely proportional with the power/energy claims of the inventor...
So, when I hear someone claims multi-kilowatts of 'FE' power, it is most certainly very questionable... Hmm,  Perendev? Etc...
"Ex nihilo nihil"
fletcher
Theoretical thought experiment of proof :
If one tri-gate can add momentum to a rolling magnet so that it rolls further from the gate apex [on a flat surface] than the distance it was attracted from, then, you should be able to make a simple vertical wheel [well balanced & very free moving (nearly frictionless)] & attach an analogue to the rolling magnet/weight to that wheel at 12.01 o'cl - let it fall under gravity with no tri-gate in the system - it should act like a pendulum & rotate to about 10.30 - 11.00 o'cl.
N.B. a heavier imbalance [weight] will rotate under its own steam to a slightly higher vertical height because the pivot friction is a smaller proportional force to that of the force of acceleration due to gravity of a more massive weight - then redo the test with the tri-gate in place [anywhere will do as its adding momentum] & if it can get past 12.00 o'cl you have OU [adjust the magnet strengths as required].
If a series of tri-gates does not need to continually reduce the gap between the gates [equivalent to the smot ramp scenario] then more tri-gates should add even more momentum to the single weight imbalanced wheel & then you could look at attaching multiple symmetrical mag/weight arrangements & tri-gates to power her up.
In this theoretical setup all potential results hinge on whether in fact the tri-gate can add momentum to the rolling mag/weight, so if it were in a wheel environment it could achieve a higher PE than it started with.
JMO's.
Evg
Fletcher
As I see it
On paper, you have just invented over unity or perpetual motion (with the help of the tri-gate)
Now it?ll take precession tooling and building a real live machine.
This is where everything falls down, who has the ability, money or guts to put it in practice?
I have seen pics and previous builds from/of your workshop and it is very impressive, but probable not good enough to build this wheel (instrument).
If only you were a scientist with a team and a 5 year government grant. Live would be different.
