Roll on the 20th June
0 Members and 196 Guests are viewing this topic.
g4macdad
Quote from: MrKai on June 22, 2008, 09:58:48 PM
With all due respect Larry...I am not sure I understand this statement...what grav-mag has ever worked...ever?
See my previous query to Graham; personally I think if there was some sort of compilation of "failure" put together that was accessible to Experimental Researchers (I think I like this a lot more than "tinkerers") doing the more boring, mundane research-y stuff it would be even easier to see these...deceptions...if they exist.
-K
Was there "deception", when the Wrights did not listen to the common notions about the possibility of flight? Open your mind genius boy. Nobody is going to be discouraged by your ramblings. What do you hope to gain if they are?
Jeez, some people.
Off shore drilling eh! LOL
Glad to see most did not fall for this!
Maybe there is hope.
Evg
gwhy!
Quote from: exxcomm0n on June 22, 2008, 03:31:29 PM
".......and now for the content part of the program..."
Since I have, for the greater good of humanity, put aside my objects of amusement (well, a couple), I remit (never submit) the following windmill tilter.
Here we have the Quinntessential "Try" Gate Wheel.
Like before:
wheel   = 4' (1.3-ish M) - white
hub      = 1' (30.5 cm) - clock face
rods     = 1.2' (38-ish cm) - black with green ends
tri-gate = orange
iron      = red
mags    = green
Outer weights ain't there yet, a man can only do so much, so fast.
EDIT
For a fast and dirty wheel face, I was wondering about the table tops they like making for patio furniture.
From recollection, they seem approx. size that could be adapted, and they're clear, like Sean's builds. Hard to hide wires and motors and such.
But it's got to be thick.
Again, I cannot leave well enough alone and I'm wondering how I could wrap the steel laminates to make them magnetized (quickly deguassed, I know) and what alignment I might wanna use and the creative windings that could come thereof.
The tri-gates are NOT symmetrical and I'm not sure if that is a "good" thing or not. I have to get some ball bearing balls (or are those spherical mags? Graham or Sean?) I only have 4.
2 of one size, 2 of another.
Ain't that always the way of it?
I was wondering since they WEREN'T symmetrical if they'd act like a staggered long rod gate.
Just me, floating in the aether ( ;) ) again, smooshing (mixing) ideas together like Play Do (clay).
Oh....the pic (graphic)..........let me know.
:D
EDIT
P.S. You can blame the altered state on Vivaldi, Tchaikovsky, Jars of Clay, Alice In Chains, Bonnie Raitt w/ Little Feat, David Bowie, etc.
God, some things in life are priceless.
Hi exx,
   I don't think this will work because you will need to get past the repulsion/attraction at the beginning and the end of the arrays. I would love to be wrong but thats how I see it. Take a look at the graph I posted. I think the Only way that a tri-gate array can be used in any working system is to have the roller mag moved into the array just after the begging and then taken out just before the end of the array. I have currently started to build a grav-mag device that will hopefully do this to some degree I have posted a pic some where in this thread that shows the basic principle. I also have a few other Ideas for builds using the tri-gate not using gravity.
MrKai
Quote from: g4macdad on June 23, 2008, 06:53:09 AM
Jeez, some people.
If this reply was actually meant for me and what i typed, I'm afraid that whatever point you were trying to make was completely lost on me...as this makes no sense whatsoever in context.
Oh yeah, and upgrade. Seriously. it has been over 2 years since the intel switch. :)
-K
http://herebedragonsmovie.com/ - Join the Cult of Reason!
Paul-R
Quote from: Evg on June 22, 2008, 05:15:09 PM
Writing this without too much thought given.
Why is it presumed that free energy is usually a vertical contraption instead of a horizontal wheel? (Unless you planning a gravity machine)
Because of the theory about energy fields that says that free energy may be extracted
if you have two energy fields acting in opposition to one another. (I don't know the whole
story on this - Bearden's site may have it). In this case there would be the gravity field
acting down and the magnetic field acting up.
Paul.
