Roll on the 20th June
0 Members and 87 Guests are viewing this topic.
hansvonlieven
Doesn't matter, the lighter material will always be in the place where you don't want it.
Hans
House
@Hans
The tube is completely filled with water, so there is no shifting of water within the tube.
If the tube runs over the center of the wheel with a rod inside and the rod is shifted from 7 to 1 the the wheel will be overweighted on the right side and the wheel with turn. What am I missing here?
hansvonlieven
If the water in the tube does not move, what is the point of it? Why not have a weight then in a U shape? For the water to aid you in any way it has to move.
Hans
OU-812
I think @House is saying he wants to put a rod in the tube filled with water with the rod being the weight and styro to help 'lift' the rod to the upper right.
I think the most common mistake here is forgetting that the weight of the water displaced (push back down-left) will weigh more than what took it's place..
House
@OU-812
There are weights on the ends of the rod that weigh more than the water that is 'moving' down to the left. Remember you can lift a lot of weight via buoyancy.
