Roll on the 20th June
JohnGalt_USA
Quote from: Thaelin on May 08, 2008, 02:01:43 AM
Mr. Galt:
   Have you by any chance done any of the afore mentioned small experiments to see what would happen? Really you should before you stick the knife in and turn it.
The turning of the knife is much more efficient. It will yield 100x the energy of Archer's wheel with much less effort.
badassdjbynight
Archer, I'm glad to see you back here.
The thing you said about centrifugal force pulling on the weights on BOTH sides is a good point. I'll give you that one. Since the weights are connected it would balance - as long as their distance away from the center was the same. It isn't in this case because the weights slide. But close enough to maybe be negligable.
Quote from: rlortie on May 07, 2008, 11:44:39 PM
Alan,
I hope you realize what you are letting yourself in for here.
As for this Archer-Quinn or what ever, IMO you are wasting your time. The design is not new by any means and is simply another example of trading hight for width. With the electro magnets (solenoids)  its more of a motor that will use more power than it can produce connected to a generator.  If the permanent magnets are strong enough to move the lever upward then why should they let go of it?
Rlortie
I was thinking this also. Even archer says that the attract force is greater than the repel.  If you remove the 1:00 attracting magnet and only have the repel side then maybe.  When I was a kid I used to think that a motor should move on its own because its always in an unballanced state that wants to move to the next position. Of course with no electricity it would just stick, caught between two fields.
The Eskimo Quinn
oh dear proved wrong again was i?? dam i hate that, so 900 kg plus 900 kgs plus no one at all is not one ton"TORQUE" clearly no mechanics on the site, you are describing lift, 100 kgs down is 100 kgs pressure upward on the opposing side. I fucking agree[/b] But that is lift not torque, fuck me, fucking crayon time "AGAIN"
Ok for the children in the room, why do 4 wheel drives go places cars won't???? torque, how do race cars take of fsater than normal cars? torque, and i dont mean different motors i mean a chevy 253V8, in a landcruiser a race care or a sedan.
diffs, gears?? ever ghear of these?? torque has nothing to do with speed of revolultion, pushbikes turned upside down and having their wheel spun will not run a power station even though they have speed??????????/!!!!!!!! true?? i think we'll all say yes to that.
now what is torque, torque is the gearing of one device against another, in this instance the gearing of a hydro turbine. which we say for experiment is a ten ton wheel of blades/fins that need one ton of torque to move them, not one ton of lift!!!!!!!!!!!!!!!!!!!!!!!!!.
take your car jack it up and put the weight on the wheel that makes it turn, may be 100 gramms may be half a kilo if its a 4 wheeler, now remove 10 percent of that weight and put it back so it does not turn, now add the same to the other side opposite accross the wheel at horizontal from each other, now add 15 percent of the weight of one side, remeber you already know what your "torque" weight is,. but when you add your 15 percent or your guy on the dam wheel, it turns, simply because it is overbalanced, and the torque weight is now covered, you are confusing balance and fall verses lift with torque.
to see torque no try it on your push bike, don't need the same weight to get it started do you? and even if you apply the same weights, the result is the same, but the reality is you can do it with far less weight because the pushbike has "FUCK ALL TORQUE"
pushbike, car, truck, train, dam hydro wheel it is simply scale and resistance, in vehicles it is controlled by higher and lower gearing so 4 wheelers can go up steep hills, whilst a race car can go zero to a hundred really fast all with the same engine, even if you strip the weight to the same.
or you can have the family car with 4 different torque setups to do each job
torque is simply resistance applied for a specific purpose, all those who argued this simple well know fact may now leave the rest of us alone.
got it?
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
The Eskimo Quinn
ok had enough of this shit, 9pm Australian eastern standard time on the website i will bury every Newtonian for ever and for all time, it will be uncontested. I told you six ways from Sunday, six machine that all do the same thing in different ways.
tonight I will give you what the Egyptians knew and is likely what was the engine for Bessler?s wheel, I will give it a new page so you wont have to look. I will call the new page Up yours at which point all communication will cease, and you can take it and go fuck yourselves. But i assure you when even your fucking wife understands your generation will look like the dumbest fuckers of all, not because you didn?t think of it, but because you had the others buried.
So you'll have free energy, I 'll have peace of mind i did what i was supposed to do.
what i can do is a Gift??????????? this is no fucking gift, you try waking up on planet of the fucking apes every day for 40 fucking years wondering why everyone is so fucking stupid.
I showed my partner the Egyptian / Bessler effect this evening she got it straight away and could reproduce it, and she is a childcare worker, not a scientist.
I could have showed you how the vast blocks were moved up the Nile, no animals on the shore no hundreds of men, no wind sails and no motors, the shit i could have showed you about this shithole would blow your fucking mind. perpetual motion is nothing but a simple toy that produces power, no matter what the type. your own history could have taught you so much.
what looks like a cup, cut from and emerald from Satan?s crown,
what is emerald green, what existed from the bronze age, why would an emerald cup found in Spain be told as though it was stone, what is known to assist arthritis? what can make a man walk in the water and fish float to the surface as the fisher king and guardian, what looks like blood but has been used for over 5000 years as medicinal.??
Copper slag is emerald green, and a grail cut from it would look as an emerald, also not an expensive item, it was and is today waste, blood from a cup, the Chinese used rhubarb for over 5000 years as a primary medicine, when you follow an object by date and story but an emerald turns to stone only when it is ancient slag with large amounts of copper in it that still oxides, until it looks like stone, and what makes fish float to the surface when a man walks in the water, when the leaves of the same plants are crushed and weighted to the cuffs of his pants. I can reproduce every known physics effect in every unexplained myth or legend in history. the grail/chalice in question predates Christ, it simply attached itself to the biblical story and can be traced right through history.
Ancient fiber optics, you name it, all can be reproduced with materials from ancient times. You might think it sad, that many good stories can be explained, I think the science in some cases more interesting than the stories, what is sad is mankind?s inability to see base physics right before their eyes.
I will continue to post on my site, but mail is finished, i cannot continue to speak to those who will not listen. and know that those who have will succeed in days after tonight. but no science can make the answers to the base questions any different.
if you think the wheel was easy this will blow your fucking mind. Your world ends as you know it tonight, as i said my partner understood it in seconds, if you do not, have someone help you walk across the road.
Thaelin
   OK!   ;D ??? ::)
   I will just wait and see. Meanwhile, I am trying to figure out how to make one of these here in an apartment. Feel the noise level will be too high. Maybe not. Make a small one and have it shift the weight via coils off a battery just to see what goes.
   BTW, just did the experiment again. This time I took a bike wheel and at equal distance I places four neo mags two inside and two outside to keep them on. Ok, now I have the even balance of two arms with equal weight on them. Guess what, no matter at what spot I move on to, it balances and stays there. Take two more neos and put them on one side and move that side up to the one oclock spot and it moves to the bottom back and forth until resting due to friction. Oh well.
  AQ, keep your thick skin, as it will no doubt get a lot more hectic before it gets better. I really do wish that a had moved out to the country so I could do this kind of thing.
t
