Roll on the 20th June
Rusty_Springs
Quote from: ramset on July 08, 2008, 01:22:39 AM
Graham so that sounds like its never been done  thank you  Chet
Hi Chet
Thats right PM has never been done by anyone including Archer as for making a magnet climb from 6 to 12 with just magnetic force yes it has been done by me as I showed.
Take Care Chet
kremlin01
Hi R S,
"Hi Archer
Your wrong again the Trigate does go from gate to gate with out having to fall, its on a level path but I'm not here to debate the Trigate, you have something show it I have shown mine going vertical.
Take Care Archer"
Oh yes, that really proves your point. Did your video camra break down?
Regards Bren.
gwhy!
Hi Archer,
   I did find your tri-gate and your track vids intresting but to be honest I also think you only showed only the down side to the tri-gate. If I may make a suggestion about the tri-gate : use an array of at least 3 tri-gates on each side put them a lot closer together ( you may want to place the gates under a piece of plexi glass ) then place the roller mag at the beginning of the array ( in the dead zone ) so it just sits there not being pulled into or pushed away from the entrance without holding the roller .  Then Just blow/tickle the roller into the array then this will show what I believe is a very good setup, as the roller will rapidly pick up momentum and then exit the array and will be pushed well clear of the suck back in.
But with all these "succes" stories of tri gates. Not a single one has put them on a circular path to see how they function. I made some other renders showing such a circular setup. I didn't get wether the lengths needed to be decreseing or not so I just made two renders. I really want to build such a setup but it's always the question of how do you start. I guess I'll manage somehow.
PS: for the guy who asked about the software used. It's just sketchup with a plugin called iRender for rendering.
The Eskimo Quinn
You still missed the point of the trigate videos, i am well aware that multiple gates can increase the speed of a light object, my point was the power component or traveller get weaker with size, and it is that component that drives the wheel if used as a shunt, having three times the amount of gates in huge size for commercial power production, to send a light weight is of no use. I never said they did not work, I believe i said in the video they were my first choice. but have no commercioal value.
I also dont ever recall saying they needed to run downhill.
for those doubting what is to come, i am loading the dummy spit video that show an 80 degree climb, this was filmed right before i went for full vertical, you miss the first half at 45 degrees for camera placement but the second half can be seen. The full vertical is longer and fixed position.
you can see the knockers really have no concept of basic year ten physics, and you can all see they are bad liars, if you are a kid ask your science teacher, or if you have kids get them to ask.
A full vertical lift takes more energy than to turn a wheel of the same height as the length one side of the diameter.
so had there ever been vertical climb continuous previous in history there would already be a wheel. Purepower should know this is true if he is an engineer. so if it is a vertical climb we have??
This is my week clowns, there was enough donations before i closed it today to buy the last 200 mags for the outside wheel track. Thank you to those people.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
