Roll on the 20th June
0 Members and 141 Guests are viewing this topic.
xee
@ The Eskimo Quinn
Is this how your magnetic poles are arranged?
exxcomm0n
Quote from: purepower on July 09, 2008, 12:32:06 AM
Okay...
Going off of your example, the ball bearing on the string would have the same velocity (and therefor kenetic energy) as the free falling bearing, just in a different direction because one is swinging horizontally at the bottom and the other is still traveling vertically. However, kenetic energy does not depend on direction like potential energy does. A moving object has the same kenetic energy regardless of the direction its headed. Potential energy must be measured by the displacement parallel to the force of gravity.
They start with the same potential energy (same height) and end with the same kenetic energy 1/16" from the bottom, regardless of path. Thanks once again for proving my point.
Now, what happens to this kenetic energy is different. One loses it all to impact and deformation, the other loses it all swinging back up and regaining potential energy.
Different systems, different end "results," same energy ballance regardless of path.
-PurePower
Yup, I never said that the energy amount was different, only the outcome.
Fine the energy balance stays the same, but the "work" is now able to accomplish a lot more towards perpetual motion (movement) vs. a dropped ball bearing (impact).
I'll take the motion, thank you.
Ya know.....we're back to the concepts proposed at the very beginning of this thread now.
:D
Ain't that a pip?
All this time and semantics got in the way. ;)
Anyway, I'll take more work out of the same amount of energy, whether reclaimed or converted into potetial energy any day.
When I stop learning, plant me.
I'm already of less use than a tree.
Fred Flintstone
Wow...this topic is at 96 pages. Hopefully we will hit 100 by the time Archer releases the fully functioning wheel. And yes, I now beleive he has solved the riddle.
Guys, dont be jealous of him. He was just born with the ability to see things that we cannot see. I tried to build a gravity wheel and I just can't do it. But, Archer can....and you will all see it running soon. The magnetic array that he discovered is brilliant I tell you. Simply brilliant!
@ TO the Non-believers  - give it up - you can't hang with him - he has wisdom where you only have knowledge.
The people will now rule over energy - just watch your back until this is mass produced.
Always Your Friend,
Freddy
p.s. What happened to Batman...Gues he is scared of AQ!!!! (or he has nothing to show)
exxcomm0n
Quote from: Fred Flintstone on July 09, 2008, 01:11:04 AM
Fred, he simply thinks to conclusion and plays. But it seems more than most others can accomplish,
Always Your Friend,
Freddy
Ummmm Freddy? Maybe you can help me........
.....what is the definitive line between wisdom and knowledge since you seem to have the inside track on the concept?
As to Batman, maybe he got his own thread as was suggested.
Then he don't have to deal with worthless non-thinking stoners like me.
Life IS good!
:D
Rusty_Springs
Hi all
I just want to point out a couple of things that cheese me off and that saying my Trigate is a Smot when clearly my gate attracts in and repels out and Smot will not repel out it will only leave the system with the help of gravity.
Second I have always said my Trigate will not work with Archers wheel because it was biult to be a permanent magnet gate not to lift wieghts, it was biult to attract a magnet in and push it out not to pull a magnet down or push it up, remember what the magnets of this wheel are ment to do it push and pull a rod up and down not move a arm through a gate, again I said many time the Trigate will not lift and repel a rod up and down it will kick the rod through a magnetic gate which is not what the wheel wants, if thats what it wants then why the slidding rod in the first place.
Take Care All
Graham
