Roll on the 20th June
0 Members and 134 Guests are viewing this topic.
mondrasek
Please see the thread "Gravity Motor Patent 7/10/08".
I would like to get this spread across the net ASAP.
Thanks for your assistance.
M.
ramset
THE fact is his flimsy hoop is under compression and flat towards the bottom it crashes into the ground at the bottom if you guys can't see that elevating and stiffening the array with a few more mags for the pull in[ which he has already shown] will make this work then you come with bias your anger is clouding your eyes
Thanks Grandma
OU-812
Maybe AQ is right.  All you monkeys just don't get it.  He has not gone on tangents after not being successful, he is just building the next 'part' in the master plan.
One by one he is showing us the pieces to save humanity and all everyone does it bicker.  but ah ha!  I've solved it and here it is:
The roller goes around the track, drops onto one end of the fulcrum, it lowers and the load drops back to the track and goes around again
The consequence of the fulcrum lowering causes a repulsive mag array on the other side to move closer to the gravity wheel, pushing the rod to the other side.  Because the mag array starts away from the wheel until the fulcrum pushes it closer, there is no 'wall'.
The wheel spins and we have OU/FE!!!
(He should have called it the Sword of Rube Golberg)
Newtonian God
Quote from: ramset on July 11, 2008, 04:33:48 PM
Newt do you have a nice pic of the back side of your Avatar? you should post that side when you talk out of your ass   Chet
Chet you fool, my avatar is Archer kneeling before the Newtonian God. Archer's backside is something that you should be intimately familiar with, it's where your head has been for the past few weeks.
ramset
MONDRASEK I cut and paste    no good   can you post a link? Chet
Thanks Grandma
