Roll on the 20th June
gwhy!
Hi Everyone,
As regards LarryCWheel. Nice BUT I have been playing around with this design for a few weeks now ( and before anyones say YOUR AFTER THE CREDIT,  I am not ) I made a few observations that need to be said. I started using this design with the smot arrangement on a 2 arm arrangement just to see if the concept would work it didn't because the sticky point at the end of the track was to great to release the roller but the climb from the roller was quite impressive. So then I went to using tri-gates ( now this isn't to start a smot/tri-gate war part 2 either, bear with me here). The Tri-gate arrangement do not suffer from the sticky point at the end if set up correctly but the down side was the climb from the roller was to say at best very poor but it did climb. Then came the Archer Smot ( don't know what else to call it at the mo ) so I set that arrangement up onto my setup but again the sticky point at the end was to great to release the roller. Now I did try a heavier roller to see if it just may be enough to drop away from the track ( which it didn't ) thats not saying that it can't be done with very carefull tuning of the track and roller weight, its just that "I" did dismiss it rather quickly because I was getting  better result using tri-gates. I have just acquired some more building materials to try and make a tri-gate version ( IMO the tri-gate version will work ) with more arms but I think its gonna be a bit of a pain to build as I think its gonna need a lot more arms than 4. Just thought I will post this up for peeps to be aware of this designs limitations...
exxcomm0n
Quote from: queue on July 13, 2008, 02:32:56 PM
So .. this is my first video on youtube and my first video here.
http://youtube.com/watch?v=7cVDYKwb-5Y
You can download it here too ( my site ) but you'll have to wait for the download to complete before it will appear in your media player..
http://relativity.ca/aquinnwheel/aqwheel.wmv
Nice vid man!
If I might make a suggestion (from what I saw)?
The big black mag, can you form those in cylinders like the rest of your array?
I noticed while watching it that they were the 2 wall areas you had.
Also, it seemed the black mags were touching other (neo) cylinders. If they are, could you maybe make sure there is an air gap between them and other cylinders and I think your wall might become much less, if not disappear altogether.
Might I propose that you try getting rid of only the black mags while leaving all the other MkE arrays in place, rotating the entire assembly 90 degrees to the left, and giving it another go?
Otherwise you are still kicking my non-contributive ass all over the place!
I'll see what i can do about playing "catch up" tonight. ;)
BTW, You have the good neighborliness to start your vid w/ "Welcome" and the self integrity to use your own voice instead of hiding behind slick production techniques.
Good to see you willing to "risk" that in the pursuit of an idea!
@ all
I'll be trying some different things tonight such as:
1.) Do the MkE array mags have to be circular? I've got way more rectangular ones to build arrays from than rod mags.
2.) Can the MkE be just as effective horizontally as vertically?
3.) Can I use a BIG ring mag and a mounted MkE on the wheel?
I'm just playing.
You know, my "million monkeys" approach as even a stupidly stumbled upon effect can mean just as much as the idea that's thoroughly reasoned and drafted before it's proven.
I hope to be posting results tonight, and I REALLY need to get back on my HHO experimentation and cell building as economics make it more attractive every day!
:D
When I stop learning, plant me.
I'm already of less use than a tree.
LarryC
@ghwy,
No problem, credit does not matter, just as long as it gets done. Thanks for the testing results, every piece of actual testing info helps.
Regards, Larry
Rusty_Springs
After seeing AQ's last video where he breaks the wall from 10 am i decided to setup one of my wheels to try and replicate what i saw or my own variation of it anyway.
It will be my work in progres over the next little while or until i appease my own curiosity ..
i had a lot of trouble to overcome the wall but finally seems maybe i broke it too ! !
Just don't have my wheel setup right now to take advantage of any gravity fall after breaking the outer wall of the magnetic array .. Hopefully i can reconfigure the array to break the wall at 3 or 4 pm instead of how i have shown it done in the video.
Making the video and figuring out all the conversion has eaten a better of my day today so far..
Back to work on my test wheel
i'm having fun if nothing else and my lady is actually helping me out too.
Here is a high res pic of this prototype you will see in the video .. i'm trying to figure out how to add it as an inline image ?
Here is the URL at youtube ..
Hi queue
Great work mate and its good to see you are using the sheild at the end, the same way I did for the onewaygate I did years ago, so your design is the same principle as mine even down to the shield at the end.
Take Care queue
Graham
Rusty_Springs
Hi exx
I just wanted to say I sent you a email with a vid I wouldn't mind you posting at your site if you could.
Take Care exx
Graham
