Roll on the 20th June
0 Members and 194 Guests are viewing this topic.
CLaNZeR
Quote from: gwhy! on July 14, 2008, 07:14:15 AM
I watched the vids and IMO you are wrong as regards the ring mags. I have looked high and low for a ring mag that you say the poles are on the inside and outside cant find any please post a link where I could get one should I want to if the type of mag that your referring to could be got then this still don't prove anything as Rusty has said that the mag is left and right polerized as you put it.
Hi GWHY
Hope the picture helps below, you should be able to find what you need by using the correct term.
Cheers
Sean.
http://www.overunity.org.uk
queue
Quote from: exxcomm0n on July 13, 2008, 03:55:17 PM
Nice vid man!
If I might make a suggestion (from what I saw)?
The big black mag, can you form those in cylinders like the rest of your array?
I noticed while watching it that they were the 2 wall areas you had.
Also, it seemed the black mags were touching other (neo) cylinders. If they are, could you maybe make sure there is an air gap between them and other cylinders and I think your wall might become much less, if not disappear altogether.
Might I propose that you try getting rid of only the black mags while leaving all the other MkE arrays in place, rotating the entire assembly 90 degrees to the left, and giving it another go?
Otherwise you are still kicking my non-contributive ass all over the place!
I'll see what i can do about playing "catch up" tonight. ;)
BTW, You have the good neighborliness to start your vid w/ "Welcome" and the self integrity to use your own voice instead of hiding behind slick production techniques.
Good to see you willing to "risk" that in the pursuit of an idea!
Thanks for the comments and suggestions . .
Re: the black mags as you called them .. see my recent post about isotropic ferrite.
Cheers
Q
BATMAN
BATMAN ...HI ALL
BATMAN WANTS TO KNOW IF ANYBODY WANTS HIM TO BUILD THEM  A GRAVITY/MAGENT TEST WHEEL
THAT THEY CAN'T BUILD ONE FOR THEMSELFTS ??
If there is enough people wanting one, I will build in set's of 12, 24,48,.....etc.
PLEASE PM ME ABOUT BUILDING ONE.
I WILL POST A PIC AND VIDEO OF THE ONE YOU WILL GET F.O.B. TO YOUR DOOR. IN DO TIME
BATMAN SAY'S IT'S TIME TO PLAY WITH YOUR OWEN WHEEL.
BACK TO THE BATCAVE.....................BATMAN............HAVE FUN.
Newtonian God
Quote from: shakman on July 14, 2008, 03:19:38 AM
Hey Newt, I'm not sure if anyone has taken you up on this yet and/or if the offer is still open, but if it is I do have something I'd like you to try.
I've mocked it up in CorelDRAW but will transfer to AI if you're still offering to build.
Send it!
Rusty_Springs
Hi All
I'm not getting into Archers rambling because anyone that knows magnetics knows what he was saying was just that, ramblings or rubbish and you just have to look at the vid I asked exx to post to see he has the same principle I had years ago just using different types of magnets, also exx is right nothing has and will come from it (the will I put in thats not exx's words), for reasons I have already stated.
I will say one thing, a donut magnet reacts the same as a cylinder magnet so you can stack them like cylinder magnets and they can also be neo, the difference is the hole which can be used for the arm of a rotor, you can place say a plasic rod through the hole connected to a shaft, this gives you a rotor and also lets the magnet roll on the stator giving you the best of both worlds.
The system I would be trying it on is Gwhy's because he may have the best gate sofar and what he posted is not old its something I havn't tryed and didn't think of, I worry about the reverse pole comming in because of the corner effect but that will not be known until a test model is biult.
Take Care All
Graham
