Roll on the 20th June
0 Members and 148 Guests are viewing this topic.
OU-812
Yes, AQ is the ONLY one in this world who can build anything and possibly bring us OU/FE.  Anyone else is an Oil Man or a fake.  AQ has PROVEN time and time again he has solved the riddle (but has just misplaced the proof).
Everyone give money to AQ.  He will bring us into the new world.  Only he can, no-one else can.  And when he just needs a little more money, then give a little more.  Then just a little more again, give a little more again.  You will feel bad and be at fault if the Oil Men win!
The Eskimo Quinn
just posted to that over on the other site, mags dont generate energy they only transfer it, what goes into the steel is lost from the power of what you are using, so if you go larger on the mags to get the same field level using steel, the cost goes back up to where you started. Unless there is some benefit i am unaware of, im inclined to thing it will polarise and you will have a flat mag centre pulling against the roller as i showed in the vids of flat mags over cylinders. but will take a look, i do not profess to know everything, but as i said it wont be cheaper as you loose power to the steel.
take a piece of steel rod, place it on the edn of a neo the same size, and then stick it to something metal, pull it off, now take two neos half the power inline and try it again, it will be much harder to remove the neos directly.
remember whatever you do to reduce the wall in these types of arrays remove the power to climb or removes velocity on the flat. Your must fire out of the gate, just like the batman vid, for those hwo thought his was slow, look at the distance betwwen them compared to mine, that is the only reason, less field over the same distance.
so you see what reducing the field in any format does.
gotta go
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
exxcomm0n
Finally.....
It's chunky and boring, but here it is:
http://www.youtube.com/watch?v=ycZpjidmrAI
I suggest you watch it without sound, the edits didn't quite work out the way I planned.
You....were warned, I accept no responsibility.
When I stop learning, plant me.
I'm already of less use than a tree.
The Eskimo Quinn
I was offered commercial funding this morning and knocked it back. You cant take money without them wanting some control in return.
If it was fake and i just wanted money, that would have been easy. Just take their and say oh it must have been an anomoly.
somehow your argument seems a little strange, so if a guy comes up and says he can cure cancer, on the way to showing you he cures diabetes, so he is still a fraud, yeah fraud produce miraculas things every day. yeah the Mayernick effect and the never before seen loop was all part of the plan.
If he wanted money he would just say hey i can cure diabetes, or i can run the worlds first magnetic loop.
what is your contibution? ou-812 ?? next time "u81" you should swallow the red pill and join the real world, we have lots of Neos here.
OU-812
Quote from: The Eskimo Quinn on July 16, 2008, 12:14:39 AM
the tinsel koal thing thing is a well funded hoax to draw you away from the wheel.
Um, you've drawn attention away from the wheel by yourself pretty successfully, no need for a well funded hoax.
