Roll on the 20th June
Rusty_Springs
Hi All
For those that don't beleave what I say about centre of gravity they can test it, just grab a spoon and rest it on your finger because the oval side is heavier then the straight side the spoon will fall to the oval side now if you move your finger closer to the oval side of the spoon you will fined that the oval side will start to lift the closer you get to it and if thats not convincing you put some wieght into the oval of the spoon and try it again again the spoon will lift the closer to the wieght you are.
Take Care All
Graham
ramset
Zero well I guess that will have to do for now  thanks  Chet
Thanks Grandma
Rusty_Springs
Hi All
Since I have been adding my 2 cent worth I will say that I think and feel a SMOT will never work with any system and the reason for that is a SMOT will never release with out the help of gravity unlike my Trigate a SMOT doesn't kick out in order for it to release it need other energy like gravity and if you need gravity to push it down then you need something else to bring it back up and theres the flaw to release it must drop and if it drops it must be brought back up to be able to drop again.
Take Care All
Graham
ramset
where is OMNIBUS when you need him ??   Chet
Thanks Grandma
Rusty_Springs
Hi All
That was funny Chet I had a good laugh there its good to get humour into this hahaha.
Ok since I was talking about experiments lets try one for centrifigual force, get a piece of string or wool and put a washer or nut on it so it slides up and down now have the nut at one end and move that end up slowly you will see the nut slide along the string to the other end you can move one end up and the other down at the same time you will get the same result now do the same but move it as quick as you can this time it wont slide down until you stop the motion and you will feel the nut as you go up hit your fingers thats centrifigual force pushing it up, if that doesn't convince you that centrifigual force play a part put something at one end of the string to stop it falling off then spin the string as you will see the nut will stay at the end your not holding until you stop the motion.
Take Care All
Graham
