Roll on the 20th June
0 Members and 44 Guests are viewing this topic.
LarryC
@All Newt's,
Where are you? It is obivious that Archer is looking for some feedback from you guys. Little pp, ng, and tk, please be man enough to show up for the final party.
Thanks, Larry
Rusty_Springs
Quote from: LarryC on July 21, 2008, 07:11:43 PM
@All Newt's,
Thanks, Larry
Hi Larry
The final party is when theres a constantly spinning wheel, using your hands to open and shut a gate doesn't mean a working principle, I can get a bar magnet rotor and a block magnet stator, I can move the block magnet up and down with hardly any force and get that bar magnet spinning this proves nothing because it can't be done automatticly, you just have to move a magnet slightly to take it out of the field to keep something spinning it was done with the minato wheel and I have done it with my overlapping magnets but to do it automatticly an electromagnet was needed, so using someones hands to keep it going proves nothing.
@Exx
Saturation is filling something with magnetic flux so it takes on the properties of the magnet that filled it turning it into a permanent magnet, if the iso becomes a permanent magnet then that would defeat what you are doing, I would think, I did an experiment where I placed a weak magnet on top of a strong magnet, they were place so the same poles were facing each other then I taped them together and left them for a while, when I untapped them the weak magnet instead of repelling the strong one like it did before I tapped them, its poles changed and it attracts the strong magnet or it took on the same properties as the strong magnet, this is saturation.
Take Care All
Graham
madsen
Quote from: Archer's websiteThe last and perfect proof of the Newtonian brainwash and bullshit is this line, the ultimate line by every fuckwit Newtonian at NASA and every other institution in the world.
Quote from: madsen
Referring to the "broken wall" video", what do you believe a "Newtonian" physicist would predict would happen when you release the roller?  How would it move differently?
And there is the real truth of who is teaching your children, the very desperate attempt to claim they know anything at all.
I ask all mankind to ask this question, if they could or would have predicted the movement at all, then why in 200 years has no one ever made it over the top of the hill from a self start? Because they did not know how.
If you invent the cake recipe, you and only you are the expert. How could someone predict something they were with trillions of dollars and hundreds of years unable to do, and said could not be done, possibly be an expert on anything.
The guy who invented the cannon, or a pistion fired by an explosion in a combustion chamber, who is the expert on the combustion engine ? the guy who invented  the cannon or the guy who invents the combustion engine.
How? it made it over the hill, something your Newtonian well educated well funded physicists were unable to do ever in history, every single piece of the discovery was outside what they "already predicted", or "they" would have achieved it first.
Your useless heroes failed, for if this powers the world for free and ends global warming, that failure is the greatest failure in world history, the entire fate of the planet itself. We have now seen in the hill climb over the top that Newtonian Physicists can predict. Nothing!
So AQ, are you seriously claiming that if you sent the specifications of your apparatus to a (Newtonian) physicist, that s/he would not be able to make a prediction (correct or not) regarding what the roller would do if you released it as in your video?  It isn't that complicated a device.  I'm sure determining its behavior would be much simpler than launching satellites or probes to Mars.
If this is not your claim, and you are just saying that Newtonians have lacked the imagination to invent a device like yours, again, what would the roller do, under Newtonian assumptions?
sm0ky2
Quote from: Rusty_Springs on July 21, 2008, 06:29:52 PM
Hi Sm0ky2
If you read the site I posted that had me talking about the magnetic current about 2 years ago you would have seen that I talked about using coiled magnetic wire or iron wire and it didn't seem to make any real differance.
Take Care Sm0ky2
Graham, was "your magnetic switch" the same as the one Archer proposed?
what exactly were you trying to "do" with the magnetic wire??
i am thinking more along the lines of a copper coil, similar to a transformer w/ ferrite core, and magnetic switch set up as a sort of 'center-tap' to charge the core, then switch it off, and collect the collapsing field.
Rusty_Springs
Quote from: sm0ky2 on July 21, 2008, 07:39:34 PM
Hi Sm0ky2
You know what a can of worms I would open if I said yes to your question, look what happened when I pointed out his magnetic track array was the same in principle to the one I did years ago but I will say I was working on soft iron not iso and what I was doing was treating magnetic current like electrical current so if it moved along a magnetic wire like electrical current moved along copper wire then maybe coiling the magnetic wire would work the same as coiling copper wire increasing the force running along the magnetic wire but as I said it didn't seem to change much so I went off that idea, I never looked at it in the way you did with copper wire.
I never claimed magnetic current because I thought it was done many years before me, I could be wrong but I even think Tesla talking about it.
One other thing up and over the hill has been done many times by many people just google magnetic motor you may see a few getting up and over the hill, I showed it with a bar magnet and my corner gate, AQ reconed I had a motor or something in my rotor when I showed it but ofcause I didn't the rotor was just a video head because the bearing in that is friction free, the minato wheel shows up and over and he has to keep lifting his stator to keep it going. up and over is nothing new, keeping it spinning is.
I was trying not to get into this crap and I hope I can stay out but if people ask questions what can I do.
Take Care Sm0ky2
Graham
PS: I found a few differances between electrical current and magnetic current and that was electrical current can travel further along the wire and electrical current needed less force to open the switch. with an electric switch you just have to seperate the wires for it to work but with magnetic switches you need to not only seperate but also move the wire out of the magnetic field so its not pulled back into the switch connecting it again.
