Roll on the 20th June
0 Members and 194 Guests are viewing this topic.
gwhy!
Quote from: X00013 on July 30, 2008, 05:42:48 PM
@gwhy
If you are for real, i'm uploading to the tube right now (just for u and maybe 4 others?) sumding dat mite help, i dont wanna post it here because it's a quick mag explination? I'm a complete idiot really. youtube X00013 ,those r zeros, not o's,,,,,,,not that i have anything against o's.
@ exx, (my rep, checks in the mail)    i did what u did, the only diference is i took my camera off of "record in stoned big blocks" setting,  ;)
Thanks for that.
Looks like quite a bit then. cheers.
The Eskimo Quinn
to those who missed some of the earlier posts, the ferrite blocks were ferrite magnets, so the effect was to turn on at a higher level, the variance when using already magnetized ferro block is simply distance, you require less distance as they already have some power, however the do not switch off completely. this also was explained earlier when i said. Make sure you ferrite magnets will not hold the roller in place without the switch, this means in simple terms, that when the switch is off the traveler will fall.
I believe I showed this in the original videos with the steel block, this was shown by queue when he switched it of and the rotor arm fell, it was shown by X00013 when the magnet on the string returned. there is no question that when switched off the ferrite be it magnetized or unmagnified will release the object in question.
so the last and only other valid question is how much work for the contact.? zero, that arm i was moving would be fixed to you wheel in advance of you rotor arm, it sweeps past an array off the side of the wheel activating the ferrite on the track. it pulls the roller forward as with any other set of track magnets yet when over them the arm passes out of the array field off to the side and they turn off.
This being the case, there is with straight isotropic ferrite no magnetic field left of any note, thus the object in motion still has momentum in addition to the free fall of gravity, and continues around to the start.
I see that the skeptic as always when they have seen what is, now know what is coming, and fully understood the implications of post 5426 on page 136.
As to thoughts of losses or eventual slowing down, what is not realized is that this is not a closed system so that rule of physics does not apply.
You see when in free fall and free space there is no system. Take exxs much clearer videos of the loop, the magnetic roller rockets around the track. This rocket effect is cost free, when reaching the end of a track that momentum is still there until it hits the wall, without the wall, the momentum clears any magnetic field and is free to enter the system again and perform the same task, only this time it is not being simply released, it is being pushed into the array by momentum, so has even more energy. The potential energy from the momentum and fall cost has already been paid for when first released.
1) We know that as a free entry start the roller cannot refuse to climb the hill and get over the other side to the wall we have all seen and accept this
2) We know the roller has momentum when it reaches the wall point. And we have all seen and accept this
3) We know that if there were no wall it would continue to travel in free space not controlled by any magnetic system back to the start we all understand a free falling object would without magnetic field interaction roll down a hill back to the start and accept this
4) We know that a roller or magnet can be moved by a ferrite block not normally able to move it when an addition magnetic field is applied, we have all seen and accept this
5) We know that if the flied can be transferred without physical contact there would be no losses to friction, we all know and accept this
6) We have all seen the magnetic field transferred without contact and know that it does move the required sized objects without contact even with rubbish grade materials, we all know and accept this
7) We have all seen the original steel block drop when contact is broken and the gate key is switched off, we also witness this with X00013?s video showing the same effect so we know that when switched off it does perform as expected, we all know and accept this.
What is it that you do not accept above please quote the number to show your intelligence level.
As for physics professors that understand this, why if they are smarter than myself have not gotten this far, if it is basic physics and they have trillions in research and this is still Newtonian physics, why have they not gotten this far and why could they not complete the task?
Because they are not intelligent at all, they simply repeat the words of others,
Me if I were a Newtonian, I would not claim it as Newtonian physics, because with two hundred years, NASA and every university in the world and trillions of dollars could not produce the machine with what was supposed to be my area of expertise, I would feel like a world class idiot. So how will that story go I wonder?
I f this ?is? Newtonian physics then they have known for at least 50 years and have destroyed the planet for money, I would believe that. After all I still want the president to do one of 2 things, Have the general in charge of Roswell noted in school historical text books as the greatest clown and idiot to have ever lived and stripped of all his honors medals and retirement benefits for have the single largest peace time military operation in history at a cost prate to current dollars in hundreds of millions of dollar for ? A WEATHER BALLOON? or admit the truth. Can?t have it both ways. We are not taking about sending 3 guys to get his lunch instead of one, we are talking more men than they sent into CUBA. Yet at no time did the PRESIDENT of the UNITED STATES even question what the hell was going on. So  he too should wear the same fate.
That?s right the only way this could possibly be Newtonian with hundreds of years and the best minds in the world studying this very field with trillions of dollars would be if it was kept from the people on purpose. Or it is not Newtonian.
Of course nothing ever happened at Roswell, the Americans just have some of the dumbest presidents in history along with some of the dumbest generals in history believed by some of the dumbest public that ever lived. Never heard of any pres candidate saying I will get to the bottom of this and have the president and generals actions recorded as idiots. And America wonders why the world laughs at them so much. Fix the history, or are there no nuts to go with that title bushy,
and yes i know about the 30 years later they tried to change the story to a listening ballon for atomic explosions, that was even funnier than the first one, becuase when someone thought to ask one simple question, they came unstuck, ok, can you show as these now defunct and obsolete plans and photos of these items now that it is declassified? NOPE. uuuumm we lost em all, what about data recording recods? NOPE uumm lost em all, this new type of material as seen in the film footage doesnt seem to match anything you have shown us, can you show us now? NOPE uuummm lost it all. if the Balloon was still just a balloon made of normal materials, then why did every last scap of common foil need to be recoverd? Thats all the questions for today and forever it would seem.
I must say however the general and the president did one good job, "We cleaned up the site because we didnt want to arouse suspicion". Good job on not having the enemy aroused of anything going on. Well done at least on that part. Yep American ingenuity at its finest.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
purepower
Quote from: The Eskimo Quinn on July 30, 2008, 06:18:05 PM
Of course nothing ever happened at Roswell, the Americans just have some of the dumbest presidents in history along with some of the dumbest generals in history believed by some of the dumbest public that ever lived. Never heard of any pres candidate saying I will get to the bottom of this and have the president and generals actions recorded as idiots. And America wonders why the world laughs at them so much. Fix the history, or are there no nuts to go with that bushy
Blah blah blah...
Ya, it's not Newtonian, because Newton didn't do anything with magnets! Tardo...
And what makes you think NASA is even trying to make a magnet motor? Even if you succeed, you haven't found FE/OU, just another fuel! And I can think of a million things NASA has accomplished you couldn't dream of. When was the last time you flew into space? Or put anything in the air for that matter (higher than your giant lever)?
And I know this post will probably be ignored. Looks like the Archirians took the high road and decided to ignore the "invisibles."
What a bunch of clowns.
If you can't beat em, pretend they don't exist!..
-PurePower
therealrasta
@ Archer
Not all the people of america are idiots.. There are many that do question what is going on and try to make positive changes in the government but at this current stage the majority just does not see it. They are simply brainwashed by media these days.. Just like most everyone else around the world is. You can not turn any news station on in the supposed free countries of the world and get the real truth.
Edit -- And America as a whole has very large "NUTZ". I mean shit.. We run around destroying countries and the nutless countries of the world just stand by and allow us too. Which I am not saying I agree with the behavior.. Just making a  point that the finger should be pointed at the world in general just not america and it's government ( which is faulty).. The entire supposed "free world" is at fault.
gwhy!
I think this is the problem. On 2 counts...    mechanical friction from the arm fixed to the wheel and magnetic attraction to the ferrite as its turning off. I know you say its next to nothing attraction but it will be there, will it not?
Edit:   Think I just realised where you said about fixing the arm. so I take it back and only say on 1 count.
