Roll on the 20th June
JohnGalt_USA
Quote from: g4macdad on August 02, 2008, 12:45:27 PM
You are trying to clutter the thread with garbage. AQ is also not required to read anything you write. Take the hint.
Speaking of cluttering the thread with garbage, can you please remove your ridiculous "No McSame! Obama for President" signature?
As I have said, I am also an Obama supporter but it is totally inappropriate for you to repeatedly shout out in every one of your posts (cluttering the thread even more) with jumbo sized text that has nothing to do with overuniity. I think your avatar says enough, don't you?
This is not a political commentary website for Americans. This is a global website that is read by people from around the world that have no interest in US politics.
madsen
Quote from: g4macdad on August 02, 2008, 12:54:12 PM
Well at any rate you have probably accomplished your goal and rendered this thread useless. Just remember what you have contributed here(and most likely anywhere). NOTHING!
My ~18 posts in this colossal 5600+ post trainwreck have rendered it useless?  All I've done is pose a few softball questions that AQ should be able to answer readily.  If AQ can't answer them, what does that tell you about his claims?
JohnGalt_USA
Quote from: g4macdad on August 02, 2008, 12:39:24 PM
This thread is not for debating the possibility of OU.
Can you please explain what "this" particular thread is for?
Bobbotov
Quote from: madsen on August 02, 2008, 01:15:37 PM
No one derailed this thread except Archer by not fulfilling his bombastic claims. Everything, and I mean everything else is irrelevant. And g4macdad can have all the schadenfreude he wants as soon as Archer does what he said he would do months ago. Short of that I am not sure how you get a thread entitled Roll Out on the 20th back on track as it is August already with nothing approaching over unity having been demonstrated.
Godmode
@Pay Attention!
Level 1: The SMOT is not for moving a mechanical load. It is merely to show the magnetic field movement.
Level 2: The Searle device is the true SMOT unit for the creation of vortex fields in a vortex. This is where the next energy level is created. But it still a mechanical model but utilizing the magnetic field in the correct way.
Level 3: The Deyo device creates fields in place at each coil. The space between is where the power comes from and the interaction of the resonancy. This is power available from a field generation mode.
See the similarities?
Now drop your spears and hammers and work to alleviate yourselves from ground based thinking.
If you humans continue to pride yourselves on the ground you own then the only ground you gain is based on the boundary you take from others.
Godmode. Give.
