Roll on the 20th June
Rusty_Springs
Quote from: The Eskimo Quinn on August 04, 2008, 05:49:22 PM
As to the electromagnet the windings (i thought this would be obvious) were around the centre of the i section. the letter i on the system does not show up as a normal capital i. It was shaped like and i beam. so the poles were the flate surfaces, the slight bend does nothing more than concentrate the filed into the centre more.
AS to pure power and plans, fan 18 volt scooter motor 45cm arms rods 15 cm less mags from chess pices and lead weights, i have already told you all the components, there were 3 arms accross each other. without having weight the lead weights etc, there is not a lot more i can tell you. I did not build the original with thoughts of replication, i was testing a theory that just happend to work.
1)every single person on this site has seen my large rod wheel shoot the rods accross, as with dusty's wheel redrider22 clanzer etc, and your "only" issue was always the wall becuase we saw on "know" the mechanics worked.
2)I have shown you the math for energy and lift in kilowatts, the electricinas here will confirm it is correct, and that all energy devices performing the same work use the same amount of power (less friction blah blah blah) but the same exact amount. so too electromagnets and permanent magnets use the same amout of power. so if the permanent mags will do it, then so too the elctromags will do it.
3)leaving only one question, is the power to the electro mag from the motor/gen more or less than the electro need to fire the rods? This is the only question for you have seen and built all the rest.
now equal and opposite reactions (i am now running you through how i worked out the original theory)
the mag repells providing a set amount of lift for the rod. this lift is only equal to the fall if the rod slides back down the tube it was lfted, lift and fall is equal, say 2 cm with a 1 kg weight (a lift you have seen me demonstrate) so the math for that is set, "unless" the weigh falls a furthe distance, which when forced to the other side of a wheel is 20 times that at least on the wheel you saw myself and others build. So now lift is no longer equal to fall. Seperation of mechanics.
No you may think hey wait a minute if i fire a canon ball on the same angle there is no extra gain, in fact if i do this with other mechanics this is not true.
and do you know what? you would be correct, and that is why to this day no newtonian could work it out, because they missed one simple detail.
half the energy of the seperation repulsion distance comes from the magnets on the rods. so haldf of the climb comes from the rod itself. the easiest way to understand this comes from lift. electromagnet power to lift one kilo rod with metal tip is more than electrmagnet to lift 1 kilo rod with attracting magnets on the end, same as static magnets. Every single human on the planet can test that with normal mags and rods with metal verses mags on the ends. so lift by perms or elctros "is" equal to fall with no extra power ecept when the rods have their own power, so extra power is equal to each rod, x however many times their power.
Now do you see what the mighty quinn saw that mankind missed for so long.?
have a nice day
Hi All
I know where going over old ground here but this device has been proven not to work with permanent magnets by the builders Archer talks about.
It may work with electromagnets but it will not be OU, every time the electromagnet firers it drains power from the battery, because you have 3 rods that means to complete one circle it must fire 6 times or once for each half turn of each rod, everytime it fires the battery is drained of that power and that power has to be replaced, if all that power is not replaced on every circle then the battery at some time will completely drain and the machine stops.
How do you get all the power used in firing the electromagnet back on every turn? I would think someone that knows about electricity would say theres no way you can do it.
Take Care All
Graham
pillager
Archer Quinn:
I beg to differ
therealrasta
Well since everyone is just chill' in and not showing anything.. I guess I will show what I am up to and how far along I am..
Sorry, no video recorder..   :'(
therealrasta
Holy sheep shit.. Sorry about the pics sizes!,, LOL  But w/e.. Anyway the two large rings still have there plastic covers on them to keep them from being scratched if your wondering.. I should be completely testing by the weekend if I get motivated...
X00013
@rasta, get the utube thing going!!!
