Roll on the 20th June
0 Members and 68 Guests are viewing this topic.
X00013
@ Galt   LMAO!!!!!!!!!!!!! That was good. I loved the video. I love Cheech and Chong, anyhow, I have an interest in atmospheric energy, as I have performed several tested myself, and I have documented them (ie. 50 watts @ 50 mph @ sealevel).  Do you have a website and or videos on your work? I would like to compare notes. Back on subject.. give AQ a chance.. lighten up a little.  You bring the F bombs out of him.. kids read this forum.
The Eskimo Quinn
hammer what you are getting is lag, or field wind up. a magnetic field exists in free air around all magnetic and electromagnetic devices.
to best explain it, it is like a sparkler at night, spin it fast it looks like a circle, a single magnet on a wheel at high speed can create and maintain a ring field that will act as if there is a ring of magnets, so to choke occurs in the same way, an object spins creating or in this case increasing a field that is accurately set until it now works against the original goal of movement, the wheel slows and reverses just like the rollers do when they hit the wall of a flat track, the field simply increases to the point it makes or increases a wall to slow and stop the device.
If my assessment is correct you will be having the wheel not slowing right down and then stop and then change direction, it will run slow to around half speed or thereabouts and just switch like someone threw it in reverse when running.
Only know the effect, not how to cure it other than distance, the bigger the wheel or circle the harder it is to maintain the field. doesn?t mean the effect increases, small wheels can weight the same as large wheels. Same as the roller loops, the bigger they are the easier they run as there is no field from the other side in the mix.
Gotta go, in the middle of doing up the new product designs for a firm as part of an interview, bout 20 million a year g'teed from the first and about 100m from the second. If i don't get the job, they get published so they do not get them free, so you will see them on the free designs list (still yet to make that a pay link for $5 and 1 dollar for updates of 5 new designs at a time per udpdate.)
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
exxcomm0n
Quote from: JohnGalt_USA on August 10, 2008, 09:18:21 PM
Perhaps you missed it stoner, this is the thread about Archer Quinn's perpetual motion machine that he was going to reveal to the world on June 20th. As much as you might like it to be about you and your failed attempts to build a perpetual motion machine, it is not. Start another thread if you want to talk about your own overunity attempts.
No...it seems about your disappointment that it wasn't the fairy tale you wanted it to be before.
As to your assessment of me or my time.
I really don't care what you think as I have no reason to.
If I wanted it to be about me, I'd try harder.
Ya know, like your incessant whining about the missed date.
You still don't do anything and your forum handle is the saddest thing about you since it (he) strove for something that you have yet to prove since all I have seen from you is the ability to copy/paste a picture.
(Yes I read Atlas Shrugged and was captivated by Ayn Rands philosophy for about 3 minutes and was suprised I had the fortitude to finish the book.
You wanna talk wind bag-i-ness, lets look to the author from whom you pick your handle.
Isn't it sad that a stoner can achieve more than you?
:D
You seem to think it was your input that kept the thread alive.........
:D
...and Archer has an inflated ego, eh?
When I stop learning, plant me.
I'm already of less use than a tree.
capthook
Quote from: The Eskimo Quinn on August 10, 2008, 05:25:34 PM
a circuit switch like the security sticker on an arm only needs pass the switch point and it will turn on, just like it sets off the alarm when you try to walk out the door with a video, no energy required
It was YOU that said "no energy required"
So after I explained to you that an RFID tag DOES require power, you countered with:
Quote from: The Eskimo Quinn link=topic=4540.msg120555#msg120555
the reader is connected to the electromagnet to turn it on, the power to the reader is already there from the wheel and it uses about as much as an led light
At least now you realize it DOES require power.
The power draw is relative to  distance.  But even from .001 cm, it is still greater than 0.
second oif the wheel is truning the power is massive
So to be sure the power for the reader isn't a problem - you up the claim to power output of the device as 'massive'.
How many watts is that?
How many watts does the electromagnet consume?
You see, measuring and knowing these things is required to determine OU.
How many AT (amp-turns) does the electromagnet have?
What size wire?
What length of wire?
How many turns?
What dimensions?
What is the core material?
Dimensions?
Applied voltage?
etc. etc. etc.
All of these questions would be easily and quickly answered by anyone who had done what you claim.
But you offer things like 'massive', 'easily', 'melts like butter'
It has been good comedy though.
I guess your 'massive' output comes from something along the lines of your previous claim of a 100kg man stepping onto a balanced 1000kg wheel providing 1100 kg of 'energy'
You went on to defend this for pages - continuously reinforcing your ignorance. Even a stupid 9th grader knows this is absurd.
(oh - that's right - you only have a 7th grade education)
Or maybe from like:
"A satellite will remain in orbit forever because it's receiving 'free acceleration from the gravitational pull of the earth'."
Without rockets it will eventually fall to earth.  No free acceleration.
So when you say 'massive' - I say yes - MASSIVE BULL$HIT.
When you say 'perpetual motion' - I say yes - PERPETUAL BULL$HIT
What IS perpetually amazing - is there is even ONE person left on this thread that thinks you REALLY made an OU device 2 yrs. ago and destroyed it to save the 3rd world or that you gave the plans for that device to numerous people or that you will be releasing the secrets of the new one SOON.
X00013
@ Galt, this is Myself, AQ, and Exxcom,  reading your post's
