Roll on the 20th June
g4macdad
Quote from: Xaverius on October 20, 2008, 01:14:46 AM
Bankers and politicians are sons of bitches, with the exception of Ron Paul and Bob Barr.  Death to the New World Order!!!
Ron Paul is a REPUBLICAN.
Phony through and through.
Off shore drilling eh! LOL
Glad to see most did not fall for this!
Maybe there is hope.
grayone
Hay g4macdad
Here is a true story of Barack Obama. Kind of disturbing. ::)
http://www.youtube.com/watch?v=cH7kT4xwddg
Now get off politics, and get back to solving the energy problem! ;D
Xaverius
Quote from: g4macdad on October 20, 2008, 05:10:39 PM
Not Phony through and through, Ron Paul is a Republican with moderate, constitutional based beliefs.
exxcomm0n
....and Obama is a DEMOCRAT.
Why does the alignment of each candidate taken seriously need to fall under the "ruling" bicameral system?
Why do people think that if they were (democrats and republicans) elected things would be any different as they still have ruled USA politics in a mock tug of war heading for the same general direction.
Stop thinking party and start thinking candidate.
Did Obama run as an independent before assuming the democratic yoke?
Ron Paul tried that (and I wish he would have again as then he'd still be in the race).
Now.....since this has been derailed even further into a free for all, I'll be arbitrary and post some actual device ideas......
There's another thread these days here:
http://www.overunity.com/index.php?topic=5064.0;topicseen (you might have to delete the ";topicseen")
That is about a verified effect that is in use in the steel industry known as fanning. You should check it out.
It has been independently verified by a member to work AND he posted hard data on the AMOUNT OF WEIGHT IT COULD MOVE!
Quote from: derricka on October 12, 2008, 05:18:54 AM
I have been able to confirm the basic "Separation" effect using Ferrite beads instead of washers.
I slipped 4 beads onto a carbon fiber rod and brought the rod between two attracting ceramic magnets, 1/2 inch gap.
The bead stack expanded from 19mm to 28mm when brought between the magnets.
The beads I used fit the rod perfectly, slid very easily with virtually no wiggle.  I won't be able to test energy ratios
or  if "OU" until I build some kind of real rig.
Parts Used
4 Ferrite beads Part #FB-43-2401 from Amidon Associates CA USA
1 Carbon Fiber Rod .198" (4.98mm)  X 24" Midwest Products
2 Ceramic Magnets 47x22x9 mm  Home Depot
2 small 1/4 inch thick pieces of acrylic used as magnet spacer for clamp
1 Small C-clamp 3" inner jaw, cast iron
and
Quote from: derricka on October 17, 2008, 03:58:52 PM
Re: my earlier post on ferrite bead separation.
I have now measured the force that it takes to close the gap, at 28 grams.  (still in finger pressure range, but more than I expected!)
I did this by placing a 54mm plastic separator tube (1gram) on top of the beads (to keep additional mass out of magnetic influence)
I then added 27 grams of additional beads and washers on top of the separator tube.  which left a gap of less than 1mm between the four beads.
Each bead in the photo weighs 1.3 grams. (10 beads measured together at 13 grams)
From what I can tell, separated beads or elements do take a bit more work to pull from the magnet, then unseparated elements. so this is not a total free lunch situation.
But that is verified as being able to perform weight shift (even if it's just 1/2 of the reported result above) using a bead form (which has been said to be not optimal) of ferrite and not steel.
But it's a known proven effect that MIGHT have less of a wall effect and if coupled w/ the Mondrasek flipper switch could perhaps shift a weight from 7 to 1.
Just thought.
I think I'm going to make a new toy.
;D
When I stop learning, plant me.
I'm already of less use than a tree.
Xaverius
Quote from: exxcomm0n on October 21, 2008, 12:55:53 AM
and
Just thought.
;D
Kool!  Vote for the individual, not the party.  Also, interesting thread, warrants further investigation.
