Roll on the 20th June
0 Members and 149 Guests are viewing this topic.
ramset
Archer
HERE WE GO
I'm in
can you post a list of needs/supplies
Chet
Thanks Grandma
The Eskimo Quinn
This one we will get everyone to agree on the theory should only take a day or so to straighten out any doubters and the materials will be whatever is at hand to show the principal.
The site is dated so lodging patents will be a watse of time for anyone who realises it is brilliant and a money maker.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
ramset
 Archer Quinn
THE RIGHT STUFF
Chet
Thanks Grandma
The Eskimo Quinn
The machine itself is very simple and the theory very sound, in fact each component is already known in other machines and everyday use.
We all understand leverage as we are taught and described above with weight for distance, we all equally understand that wave machines are limited to the force of the wave applied to the surface area of the paddle/wave receiver that is moved by the wave, the same applies to wind turbines they are limited by the power of the breeze and the surface area which is affected by that breeze and each is then bound to the friction losses on the shaft and gears with the rest of the energy going to turning simple generators.
This device simply uses basic leverage to turn small energy into massive energy.
The basic structure is a tower, in this case we shall say ten meters tall, with a one square meter paddle at the base for the ocean model.
We will say for the sake of argument that the wave action on the square meter surface is one ton, which means that at the top of the tower the power leveraged is now ten ton at ten metres. The flaw in most designs is that when pushed forward the lever will stay where it is.
Why because the weight of the lever will keep it there and the base is being helped to keep it there because of the direction of the waves. However
Now take a simple weight equal to the lever and place it on the bottom, let us say for the sake of argument that it weighs 400kgs and the weight at the base is 500 kgs, we still have 500 kgs power at ten metres giving us 5 ton of power.
The second component is mechanical, the wave paddle when it reaches its optimum forward motion point has a simply release rod connected to it that unlocks the paddle forcing it to turn to the side 90 degrees, so it is a thin blade when running back through the water to the start point where it hits a simple static catch point that turns the blade to face the front again, wave comes and the cycle repeats.
The weight of the base ballast being heavier than the tower provides that additional energy require to straiten the paddle as it tries to return to center.
The wind tower is simply the same machine built in reverse, use the sky waves or wind to move the paddle at the top with the same mechanics to turn the paddle. If you simply hold your hand face down and move it forward and then turn it on its side to move it back you will quickly understanding the action.
So now to the skeptics. Why won’t this work and produce at least 5 times the power of every wave device and wind turbine on the market? If you cannot give a logical answer, bugger off. The SOG relies on leverage greatly so this will be important when the time comes that they understand this machine.
hansvonlieven
Groooaaaaannnnn,
Hans von Lieven
