Roll on the 20th June
0 Members and 147 Guests are viewing this topic.
AB Hammer
The Eskimo Quinn
Welcome back. I look forward to seeing your diagrams and photos. You need to post your web sight again for all the newer people here. I do hope you have better luck than the last time.
Good Luck
Alan
ramset
Mr Quinn
Anyway, that you can present through actual example , or explanations step by step ,will be fine by me
I realize this is  a low budget endeavor to show your idea ,and greatly appreciate what you bring to the table in these times of change and hard ship
Looking forward to your posts
Chet
Thanks Grandma
The Eskimo Quinn
The principal for this one is simple, to get the picture in your head I suppose is the easiest way to get you to more easily grasp the device. take a simple dual A frame tower, that would look just like the towers that support ferris wheels on a small scale picture a fly swatter suspended about and inch from its end at the axel point. the wave comes through and pushes the blade section, and when it reaches maxium point as set by you (which would be best distance swing at low tide) the mechanics as described, be it a control rod or other device twists the central shaft turning the blade on its edge.
with the added weight at the base of the blade being slightly greater that the weight of the requirement to make the pendulum return to centre, it simply swings back to the start point.
with the blade on its edge it has virtually no resistance to the waves coming through. as it reaches centre a simplt static arm connects with a point on the blade to turn it to face front again. I imagine there are many number of ways to trigger or control the turn of the blade, the entire shaft could turn or it could be just above the blade section itself. salt water is a factor limiting the use of springs etc.
however just like the guy how has a set amount of power to lift the car, the wave has a set amount of power combined with the blade. the variance is the lever, the guy can lift the car with the lever so we know that with the same power we can move more weight or turn bigger turbines.
naturally the movement at the top is far shorter than at the base, hopwever the movement at the top is equal to the distance current wave machines move now. the difference is a current wave machine is a guy without a lever moving about half a meter to a meter, the new nachine is simple a guy or wave machine with a lever. the distance is increased at the base, but the distance at the top though less than the large arc swing is still equal to that of current machines yet with up to ten times the power (lenghth of lever variant)
the reason it is so brilliant is that the cost of high tech wave machines is massive, this is very basic and cheap by comparison and produces vastly more energy.
The reason you need to understand this, is so you understand overunity, the guy who can't lift the car with his set level of power, gets a lever and can now lifts his car with the same amount of power, more power out with no more power in. So now think of what that means in term of what moves the lever? in this instance it is waves, what if it is magnetic? you are not increasing the power level are you?
get the understanding of the wave machine and what set power is, and we will go onto magnetics afterwards.
And for any moron that say it is not extra power it is simply the power that was always there can bugger off, the guy lifting the car, if lifting a set of scales to measure KW power output from his strength, cannot lift the car on his own.
PS no one cares what this means in terms of physics whether it does or does not break any laws, they just want extra power, levers through the example provide it, if we get more power out than is put in, end of story.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
hansvonlieven
Quote from: The Eskimo Quinn on March 10, 2009, 04:48:01 AM
and just for record your metaphore is bullshit, there is a gain, so you are saying ya dickhead that a man using all his strength who can't lift his car, goes and gets a lever and lifts it, there was no gain from the lever with the same power input?  That one single example has always been the ultimate proof of a set power level with and without the lever, you are a dickhead, go play else where.
Archer, you should really read a book on elementary physics one of these days. It might teach you something.
Hans von Lieven
jadaro2600
I can't believe how many posts and how far off topic this thread has gotten!
