Roll on the 20th June
0 Members and 154 Guests are viewing this topic.
ramset
Archer
Thank you for a piece of the idea ,I see this is one part of a bigger concept[ I changed a van tire this way
At 6 foot two 225 lbs  I could reach pretty high and place the fulcrum closer to the load
That coupled with the rage of one of my driver's leaving the shop with no jack, probably sent the whole event Over Unity
Chet
Thanks Grandma
The Eskimo Quinn
Well this is actually not off topic, the machine is designed for two reseasn the first to show the is a far more efficient design using leverage for the current wave machines, and for those that understand basic physics (unlike outr friend Hans who thinks that men are strong enough to lift cars on their own and that a lever provides no free gain) the subject matter is to show the principal of the wheel from a new angle, if i can get you to understand this, and then if you also understand that a power source is a power source, regardless if it is a 10 KW diesel motor or gas morot or electric motor or wind turbine or wave, that 10 KW of kenetic energy from any source used to move an object, can apply a gain through leverage, in this instance the wheel. But until such time as evryone understands fully the wave machine i will not be discussing the applicaton as it applies to the wheel.
My error last time was to give all the information at once and have to argue 1000 different points, we will dismiss the idiots as we go. So if you think there is no free gain in leverage, and that men can lift cars on their own, you may as well leave for lala land now, for those who understand there is not one single ounce of extra enefy provided by the man lifting the car with a lever, and that there is a free gain. then stay, this is not a debate, if you do not belive it, then other than being from an oil or energy company you would have no reason to stay. If those who are staying are wrong, then why should that affect your life? If we are nothing but morons then there is nothing to see here, move along
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
The Eskimo Quinn
for those of you who spent many hours with the mayernik array, what one thing did you learn about it? forget the wall, you learnt that you could self start, you learnt that you have an ocean wave at your finger tips. This will come into play for those designs as well by simply have the roller on a pendulum
ramset
Mr Quinn
Looking forward to your methodical approach
Chet
Thanks Grandma
johnagain
Gday Archer the top of the morning to you.
We are liveing in perilous times.
Thought must be given to construction that is element proof high winds floods heat cold etc.
While it is sensible to construct shelter out of concrete and steel with shutters on openings etc.
This haveing the advantage of makeing buildings insurance proof, and to some extent element proof.
Our energy devices can be constructed out of steel and concrete
Concrete wheels are heavy durable and easy and cheap to make. These need ingenuity and planning
but can be mass produced.
The fact is Archer not every one can understand you is it possible for you to please draw simple 3d drawings that a child could build from Thankyou in advance.
Your fly swatter is compared to the Americas cup and the winged keel.
I would like to see a weights upward motion converted to more upward motion thereby causeing  an upward travelling weight to to continue travelling upwards propelling itself upwards even more so..
Thankyou for keping on keeping on
All the best john
