Roll on the 20th June
The Eskimo Quinn
Quote from: X00013 on March 16, 2009, 05:48:33 PM
For the wheel, maybe use a motorcycle wheel, then use thin slabs of lead bought from home store, about $1US a pound,  tape m to the inside and balance it           http://www.youtube.com/watch?v=T2AuivYzaBs
I was thing of lead but like a larger amount of it, more like a large farm flywheel from a hay baler and pouring molten lead into the inside, this way I have a bearing and adding or subratcing weight is as easy as a small LPG blow torch, I am thinking 100kgs plus for the first couple of wheels, once the machine is working, then step it up in weight until it is house viable, at least with the lead it will not really increase the size very much at all when upscaling< anyone with an existing wheel can simply add weights to check the machine works and then rebuild for a generator version.
Am going to go with light sensor so there is no friction switch if i can get decent ones, so the lower arc will activate when the arm is over it, simply reproducing what i originall did by hand touching the wires to turn it on and off, light sensors use only milliamps so they should have little impact on the power, and of course the wheel uses no electric energy when arms are not over the sensor, so even in basic math, if the machine is unity when the electromagnet is running when it is off and turning from gravity in the gaps there is no power use of what is generated by the gravity.
for those that missed the 6000 post of arguments, yes you are correct in that lift will equal the power of the fall, PLUS friction, so the argumant was that the operation component was not unity at all, suufice to say that is wrong, you see the arms have rods with parmenent magnets on each end, so the permanents are responsible for half the distance of the lift, where an electro magnet lifting a piece of steel is responsible for all of it. So we can safely say that it is easily unity or even overunity at the point.
So knowing that no human that is not an idiot can say that the lift of the magnets is not less than the lift of the steel, we no we have a gain, Ok I accept that the magnets are a form of stored energy, thus can be called batteries which provide a power source, My claim was only perpetal motion for the life of the magnets, and if that constitutes free energy for 20 years, then that is good enough for me. Semantics as to whether or not it is in physics overunity or perpetual motion are not wanted here, I wish to provide free electricity from the machine with no fuel costs. Nothing more. I have my beliefs as to what it is, and we shall leave that question alone this time, you can call it a mgnet battery motor for all I care.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
X00013
density of Lead is 11.35kg per cubic desimetre  , you want 100 kgs , OK, if i am correct that's about 220 pounds ( sorry, I'm used to imperial),  believe it or not, that's  not that much lead, so the wheel will be alot smaller than you imagine it seems, Take a spare 16 inch tire about 5 inches thick wheel from junkyard cut a big enuff hole in it and pour in your lead, submerge the tire assembly in ice water while doing this, and wear a breather mask. the lead will need an additive to prevent it from falling apart due to impurities like dirt grit and oils and rotational forces, like throw in wire mesh, kinda like cement needs rebar. Carbon glass works best with lead but it is expensive. Brilo SOS pads steel wool will do. If it were me I would use 24 inch chrome wheels with powder coated flames,  pimp it out a little!!, that would be heavy!! like fork lift heavy!!!
X00013
One cubic foot of lead is about 321 kg or 708 pounds. I forgot to mention that.
The Eskimo Quinn
Quote from: X00013 on March 17, 2009, 09:38:46 AM
I used to cllect and melt down mine into ingots (an old baked enamel loaf tin) was not aware it was that heavy for size though, but when you think about it in respect to steel I suppose that isnt that bizzare. Its an easy buy, you just buy it off the scap dealers for more than they get, it saves collecting it or paying big bucks for new lead.
when you melt it and a normal campfire works well in a cast iron pot or cauldrin, all the crap forms on the top so is easy to skim off.
Justalabrat
Quote from: X00013 on March 17, 2009, 09:32:22 AM
Be Carefull molten lead and water do not mix well! Don't ask me how I know.
   John
