Roll on the 20th June
0 Members and 89 Guests are viewing this topic.
The Eskimo Quinn
how do you define irony? me sitting writing and lodging patent applications for energy devices whilst running off an inverter because the power is out  ::)
1 lodged 3 to go
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
The Eskimo Quinn
While you are witing I am posting the abstract of the primary patent as it has not actual disclosure of patent information.
2 hour sleep in 48 hours (when you see it is as easy as making a cup of coffee you will pull your hair out) :o
Abstract
An Over Unity Power Generator - The discovery in the prior patent application design showed that by spending a few extra cents worth of energy rather than trying to conserve every ounce, that other resources develop, in that design it was the ability to have two falls from the top vertical position of a lever with only one lift and not requiring twice the weight to do it. It was no voodoo or trick of words in the patent description it is seen every time you tape a penny to a pushbike wheel and let it go from the same position, it almost makes it back to the top, the Over Unity Power Generator base unit lodged by the same designer and IP owner company as this application. REF: SPEP-13631587 simply spent the extra energy to complete the rotation and that small expense changed the entire dynamics and control capacity of the device. Which led to various exercises in separation of mechanics using that same right angle to motion switch to enable this device, a device wherein a separation wheel will continue to rotate whilst ever the machine operates, further that the rotation of the separation wheel is run (after the machine cycles several times up to its operating speed) for the first time solely on that illusive momentum that is always lost, further that on a 20 metre wheel the size and volume of coil arrays on one side to the opposing magnetic array as an induction motor is approximately 25 times the induction volume of the largest wind turbine with a same weight factor a faster speed of rotation.(most large turbines are 25 metres high) However the energy to run the primary wheel is one tenth less the cost to run, than it produces itself, having not only an over unity device as the primary wheel, but a secondary wheel that also captures the momentum from that wheel.
Oh and because we do not need the sun or the wind can be built underground.
As with the discovery in the originating patent, over unity was hidden from any rational sight with the device requiring itself to come to a complete stop and then self start again. This removal of continuous motion is why it was never discovered, perpetual gives the mental picture of continuos motion, and whilst the separation wheel may spin forever it is driven by a device that stops and starts.
dirt diggler
Can't wait to see it Archer, sounds awesome.  Any chance of a sneak peak?
No, really, I love beating my head against this wall.......
ramset
Mr Quinn,
Sounds like a "winner".
Chet.
PS
Couldn't happen to a more deserving Guy!
@ Diggler ,
Good to see you!
Thanks Grandma
WilbyInebriated
Quote from: ramset on August 12, 2010, 12:32:25 PM
Mr Quinn,
Chet.
like archer's last one chet? ;)
speaking of archer's last one,
Quote from: ramset on April 22, 2008, 08:52:52 PM
MY lawyer once told me never give a man a stick to beat you with   this fellow seems to be handing out an awful lot of sticks     anyway I will have my frame ready for the 20th   Chet
how did your replication ever turn out?
