Roll on the 20th June
The Eskimo Quinn
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Patent day today
was a little out on the energy production re cost of machine, forgot to add 10 metres per second per second  ;D ;D ;D ;D ;D ;D ;D ;D, the test device works fine, all of you will be able to build the device from what you have at home without spending any extra money (exlcuding generator of course) and building for yourself only is not a patent breach.
Me Ill be selling them under the patent for my rewards for those who cannot build for themselves, so i have covered my conscience and my wallet  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Those wanting early copies send me your email addresses, will be emailing next week, to all those who provide them and universities etc.
TMQ
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
spinn_MP
"The Mighty Quinn",
in 2007, you claimed that you filed several patents for your inventions.
What happened?
Ooops, almost forgot...  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
The Eskimo Quinn
I did, not for free energy devices, for engineering devices, and I am sure that if you troll back through the threads you will find that is exactly the case, nice try but no cigar. There is no need for hecklers anymore, anyone who had any doubts, "who was not an energy company man trying to put people off"  would have asked for a copy as noted above. As to any questions I am sure those who have already read it can answer that for you, you see it was so simple and clever, everyone who read it so far knew it worked without having to build it.
I know, it will destory most super funds, but i think we can safetly say the energy companys have destroyed more of peoples incomes and would have continued to do so. if you work for an energy company, look for a new job, it happens every day when other companies go broke, energy company employees have no rights to special treatment above the rest of us.
Read below.
The Eskimo Quinn
This is the actual abstract from the lodged patent. reading this alone should show you, if not, the even lego is too complex for you.
Abstract
This is primarily a class one lever as described in general mechanics though
does have attributes never seen before in leverage devices.
As a layman’s instruction guide, we are using the glass sphere or cube physics
effect found within the water, the self bearing effect for want of a better term, we
have designed the lever so that it primarily rotates around the water until the
water is positioned at the end of the lever. Take the imaginary sphere filled with
water and hold it at arms length and rotate the sphere a small amount, the water
excluding the adhesive amounts on the inner wall stays where it is, now replace
that with a cereal bowl or half sphere from your kitchen, half fill with water and
repeat moving it about 10 percent of a 45 degree rotation, you will note the water
performed exactly this way in your half sphere, now look at the position of the
water, it is now on the end of a lever, this is the primary component of the device,
we simply did not load the water onto the end of a lever which has been the error
since the first water wheel, but made the entire lever hollow or encapsulate so it
would act in the same manner as the bowl, as soon as the lever begins to rotate
the displacement is almost immediate as the bowl/lever rotates under the fluid
medium, there is a tilt component also though flow is not notable, this simply
adds to the speed of transition. Water is poured when one side of the bowl does
not rise, when it rises (the short side of the lever) you are rotating it under the
water. This device simply revolves the lever around the weight until it is at the
end of the lever.
The Eskimo Quinn
Energy up equals energy down, but not when you dont have to lift the overbalancing medium to the end of the lever which you need to do in one go with an ordinary lever, otherwise as soon as you start to place it there it simply starts moving, and there are a few other components such as self increasing its own leverage ratio. weigting the end on its own also does not work, you simply end up with the same energy out as in, this device beats every contingent, and the power output is massive, megawatt massive, not pissy orbo tech.
This was simply the start, the physics discovered along the way, now has multiple designs for these type of machines and general every day applications
