Roll on the 20th June
0 Members and 71 Guests are viewing this topic.
The Eskimo Quinn
a kilowatt second is not a component of a kilowatt hour, a kilowatt second is a kilo watt per second, a kilowatt hour is a kilowatt per hour, you are imagining that there are 216000 kilowatts seconds in a kiowatt hour ther are not, i kilowatt second is equal to one kilowatt hour for total produced. i gigawatt hour is 1 gigawatt produced in one hour and so on. My math person is a working 40 year veteran electrical engineer. a seconds component of a kilowatt hour is a milliwatt hour, your equation would suggest that 24 ton could be lifted 10 metres in one second with 250watts, fall being equal to lift over the same time.
futher i assume you have not read the patent, 1 pump equals 6000 litres pumped up 20 metres  using 15 x 100 watt solar panels  this is not an equation it is a standard solar bore pump. this is just a method as an example, it can run out of a stream or be produced from rain, it is a hydro lever. and as an example that is a crappy pump, and expensive pump will do twice that on the same solar input.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
The Eskimo Quinn
For those wanting the answer to the bessler wheel gravity solution, it is contained on the future page of the enerventure web site. There is no descritpition for obvious reasons, however any half decent builder will see how it was done in seconds, this was what i was talking about when i said it had been done. when the design discovered fall did not equal lift.
Alexioco
So the hydro lever may be the same principle as besslers according to the enerventure website? http://www.enerventure.com/Hydro_lever.html
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
The Eskimo Quinn
http://archurian.com/The_Key.html
This should really stick it up every Newtonian that ever opened his mouth, but then the expected response will be easily guessed, oh we always knew that. Suck it up children its over. I FOUND MY PRICE. and most of you will not like it once you see the key can be demonstrated at will by "anyone" in any house without spending a cent.
The Eskimo Quinn
The SOG has the physics clarified for all builders and for all to see on this page
http://archurian.com/Other_Physics.html
I do not read posts on any site regarding the devices or make comment on other comments, so as not to be drawn into government run conversations, the answers and physics is there and can be tested by a housewife, if you are dumber than a housewife, feel free to show the world how stupid you are in your comments for others to read.
