Roll on the 20th June
0 Members and 131 Guests are viewing this topic.
sm0ky2
here is a quick diagram, i used the length of a 22-inch rod with a 4-inch displacement. giving lengths of 15 and 7 inches, respectively.
when you know the forces involved, and the (avg) speed of the wheel,
you can calculate the momentum at the entrance of the magnetic field, and contrast that to the "wall" entry force when entering into said field.
This can be compared to the potential energy of the 'drop' of rod end at max height to bottom-dead-center. E = mgh, which is coincidentially the potential energy gained by each rod during transition, this is equal to the total energy around the loop, divided by the number of rods.
My latest build has 2 rods, each having two ends, thus the potential energy gained by each rod during transition is equal to 1/4th of the total potential energy of the cycle.
Thus (1/4) E = mgh
Contrastly, the total energy gained by the cycle, can be determined by multiplying the the energy difference between the momentum of the wheel, and the reverse momentum imparted onto the wheel by the magnetic array "wall", by 2 times the number of rods.
Thus: (1/4) E =  sqrt(m^2 + p^2) where m is the total wheel mass,
        and p is the difference in momentum.
In a symmetrical situation,gravity vs magnetism, these two "E values" are equal.
  In the situation that we have here there is a difference in force between the magnetic and gravitational forces. Which results in a net-gain in potential energy, which converts directly to kenetic energy and fed back into the array on the next rod entering into the field.
(1/4 rotation in this case)
sm0ky2
in terms of Force:
if we assume a 11.34 kg wheel (25 lbs)
and a 0.1134kg mass per rod end (1/4 lb)
then we have 5.37 N required to move the wheel, subtracted from the 8.89 N of force delivered by the leverage, resulting in a net gain of 3.52N of force traveling across a % of the wheel. that % is measured from the 'drop point' to the entry of the next rod, then added to the complex part of the equation, which involves the leveraged curve of transition.
This competes with the repulsion force of the array (wall), up to the point of entry, then decreases as leveraged gravitational force takes over.
my math isnt correct on the transition phase, because the numbers arent working out the way they should...i think for absolute accuracy you have to integrate the rod-length over an infinite number of distances between the two lengths, and calculate the forces up+down for each point, but at some finite number of lengths the variances should become negligible... i was using the number of array-magnets as length-points, but apparently there are other things going on here, which effect the gravitational constant, so im going to leave that part of the math out of the thread until get it worked out properly...
we'll just call the value (transition), and know that it is aded to the force over a curvature scale as the wheel spins through that stage of the cycle...
hope this helps out for those of you who are trying to understand how this wheel works..
i'll quit being boring now and get onto to somethig more fruitful...
  like... The Arc
Notice here in this picture how the arc follows the end of the rod, as it translates across.  It starts out far away, and moves inward.
Now, this is very important, because you must maintain "lift" of the rod all the way up, so as you build your arc, pay close attention to the amount of lift you have, vs distance between the magnets. This will change slightly the steeper the incline gets, and approach maximum as the angle of the rod nears the horizontal axis.
also angle of approach to each array-magnet should follow the radial-line of the rod. - the exception to this being the entry-angle, which should be greater than 90-degrees.
[ note: The approach angle may varry if the magnets of rod and array are of different size/shape/strength]
It helps when placing array magnets, that you turn the wheel and bring a rod-end into the wheel by hand, and "feel" it, you want the distance and angle to provide the maximum lift for the least work. Do this for each magnet in the array and securely mount them in the proper location.
The Eskimo Quinn
So happy to see Smokey and others who believed it was the answer and that it had actually been done before, though struggled to reproduce it, to Helmut and Chet who also never doubted and to Joe Mayernick who rallied everyone to help fund the Builds and the discovery of the Mayernick array. To all who supported Me and all who had input and made builds all over the world, from Q in Canada to the many others who replicated what I had provided (though erratically and poorly filmed and described.
To all others, you can suck our cocks, Yes independent builder (aside from cutting a piece of aluminium) i instructed only, each and every component is filmed and measured on film for size, The Mayernick was rebuilt ( a great deal more solid and neatly) with full clear view of something that defies the laws of magnetic fields and newtons physics of more energy out than in.
No object can self propel or run without another source of energy
No object can lift itself without an external source of energy
A magnet or series of magnets cannot be considered to lift itself as once lifted cannot release itself from the field or track
A magnetic track cannot be considered as free energy even if it could get out of the field such as a tri-gate track as it cannot return to the start
An overhead loop that can self start cannot exit at the end of the loop as the power required for lift creates a larger exit magnetic wall
These are the laws by which Newtonian corruption of the truth has held back mankind from being 1000 years ahead of where it should be. There are several films of supposed machines of grav mag drives, but none show the workings or how to build them. The videos are already completed and will be uploaded, on Monday after the message to the world that the person who beat and defied Newton and shared it with the world is Brothers with Gaddafi, and that the tyrant Obama who told all Americans to go fuck themselves, when the will of the people defined by their elected members of congress who voted by majority not to continue in Libya was rebuked by the president who said to all Americans go fuck yourselves, I Obama and the CIA run America not the congress elected will of the people, there is no democracy. So i will be adding this to the film, so all the world can see the truth of this tyrant and that the people who define the future of mankind are against America and all NATO allies, and that this working device and many others are for all free men and that OIL Gas And coal no longer have a Value.
The Mayernick you see has been sent to the builder who is an electrical engineering student in the field of generators and motors, for the conversion to a usable power generator, the base unit that runs itself can be built from the filmed precise dimensions.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
ramset
Mr.Quinn
Good to see you looking in ,Its great to see smOky 2
Sharing His Build with the other talented Open Source Engineers we have here!
And Yes The world needs this more than ever,It has become a real "Obamanation"......................
Glad You still Have that "Feisty Tude"!
Chet
Thanks Grandma
The Eskimo Quinn
Quote from: ramset on July 03, 2011, 07:19:39 AM
Mr.Quinn
Chet
embeded
<iframe width="425" height="349" src="http://www.youtube.com/embed/jFazyyPh2iQ" frameborder="0" allowfullscreen></iframe>
link
http://youtu.be/jFazyyPh2iQ
