Roll on the 20th June
OU-812
Quote from: Glassglue on May 23, 2008, 10:07:52 AM
... Where would all of the heat go that this free energy eventually became?...
OMG You solved it and Al G. is dead wrong!!!
Global warming is NOT a result of greenhouse gases and all the B.S...in reality it is the Eskimo (and all the others who have not let on they have a working version) generating unlimited free energy and no way to use it all!
Those farkers are heating up our precious earth because they cannot use all their free energy!!!
rlortie
Whats all this polarity and "ground" debate about? you cannot have negative without positive.  Its going  to flow in one direction no matter how you hook it up.
Us old timers have known for years that the first satellite (Sputnik) launched in 1957 was accompanied  with a flower pot full of earth trailing behind.  It had a "ground rod" stuck in it.  How else could they have completed an RF loop without a ground?    :-*
Mark69
I am giving Archer the benefit of the doubt and believe that his device will work.  If it doesnt, then it doesnt and everyone keeps trying.  At least he is trying and sticking it out through all the negativity.  I dont know shit about electricity and physics, but maybe that is to my advantage because I dont know what wont work because of laws made up from some old, dead people that had old technology.  Remember, everything that was invented before had naysayers that it wouldnt work.  Plus it is funny reading all his posts that contain "fuck" lmao  Gives us something to laugh about with gas going up in price everyday.
Hang in there archer, watch out for the oilmen!
Redrider, am interested in seeing your video
Mark
infringer
Everyone has there reasons for not jumping on the build mine is simply a lack of space for having crap out for testing in order for me to build I would have to either ....
A.  Get eaten alive by mosquito's with my hopeful trial and error...
B. Build this thing in the time period of a couple of hours when I am the only one home....
I'm going for B and I will need specifications to accomplish the task comfortably in a short amount of time.
Redrider22 why do you not document more specific design?
Put it this way at the chili cook off chili is not just chili canned there is an intricate recipe that each participant follows...
So how about some measurements and a parts listing and further specifications on placement of things measurement yes I know bummer we all wanna see numbers but hey if you want this "Rapid Confirmation" that you propose why not contribute to the rapid confirmation...
4 times around the bend will get you pretty much no where close to confirmation sorry to say that could be simply built momentum...
Post your video lets hopefully have it running for a few minutes or so before it falls apart this time from there we shall progress...
Patient be patient we all have been awaiting archers final design plan you can be this as well I hope!
-infringer-
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
sm0ky2
im sure theres some flux-to-mass ratio data collected somewhere...
to give exact specs would be a rediculous issue. Start with a wheel.
the wheel should be a LOT larger (heavier) than your magnets.
the rods can cross at a range of angles, but my suggstion would be evenly space turn them 120-degrees and place the next, then 120 more for the 3rd.
place your sliding rods in the tubes and get them so they slide back and forth freely.
the size and spacing of the magnets will depend on ::
1) the overall mass of the wheel - which we can adjust by adding more weights.
and
2) the weight of the sliding rod + magnets + counterweights - which we can adjust by adding more weight.
trial and error, and constant adjustment seems to be the logical solution, without having a full range of data to know what size magnets/spacing to use for a given wheel mass.
what you look for at the top is for the rod to "catch" and pull away as the wheel turns from the rods leverage
what oyu look for on the bottom is for the rod comming in to break through the wall and then lift upwards away from the field.
then you adjust the top and botom fields to match their actions with one another. like a lift+push
and gravity does all the work.
