Roll on the 20th June
0 Members and 152 Guests are viewing this topic.
capthook
Quote from: redriderno22 on May 26, 2008, 08:05:03 AM
Archer, how can i get the rpm's up?
You would need a gear or pulley setup to increase RPM's.  When Archer was still building this  :o he was using pulleys.  Pulleys are a cheaper and (IMO) more efficient solution as pulleys can be upwards of 92%+ efficient.  I figure 120 RPM's would be the minimum target...
Sweet to see Clanzer building!! - the preeminent builder on this forum (IMO again  ;D )
@ Clanzer:
What are you using for a bearing and what method are you using to mount it to the wheel?
CH
noonespecial
Imagine Sean's assembly completed. Now remove the hacksaw blades so each weight/magnet unit is independent of one another.
Place opposing magnetics on the ascending side (left, assuming its rotating clockwise) which will move those magnets in and create the overbalance condition. Yes?
ramset
NOONE The rod gives many benefits  working together both fields have less to fight about and more power to get the job done   remember there is a whole component you don't see yet a few pages back in this thread Archers diagram on how to put the weights 33% past the mags [outside the wheel]   Chet
@RedR I believe to increase  wheel rpm requires more rods/mags also power increase   along with mass of course
@NOONE REDRI has the whole rod concept in his vid {SORRY REDRI] just one   rod of three required  Clanzner is using 4 adapting a previous project
Thanks Grandma
noonespecial
Quote from: ramset on May 26, 2008, 12:04:04 PM
Thanks Chet. I guess I should wait to see the completed design to fully understand.
infringer
A gear box or pully with more weight will be required to achive speeds needed for generator hookup....
Redriderno22 this unit look pretty promising thank you so much for your video and it is very very clear picture well lit or not the video is nice quality.
Great job on the video and great job on the build I assume that I will too be building soon enough...
Now all I await is a finalized video showing this in action in the mean time I shall order magnets.
Soon we will be discussing the best generator to use for this I would like to start off with a less expensive generator if possible or maybe we can simply just use DC motors or wind turbine type setups....  Like Mr. Piggots generation
Speed is not neccasary nor is a generator I suppose... Weight may indeed be important though depending but I could think of power generation based on little torque as well though I make no gaurentees Ideas should work in principal...
Take Care,
-infringer-
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
