Roll on the 20th June
Bulbz
Quote from: ramset on May 27, 2008, 10:55:46 AM
Bubz I don't think anyone can debunk at this point    that would require a crystal ball   or a mind meld[vulcan thingy]    sort of silly without all the facts! !  Chet PS im not so sure YOYO is a silly guy PPS and Archer is not being timid with the info  but he's just one guy    NOW building two devices [it seems ] for the 20th
or at-least helping with the 1st
I completely agree with you, and the people that are working on the project are doing a good job. I just don't like it when some flaming Noob, joins this site and then starts calling people Jerks. YOYO sure sounds like an oil bandit to me :P.
Best regards.
Steve Ancell.
ramset
This concept{Archers] is definitely an inspiration one could imagine many ways to monkey with this idea [bendix coils reversing polarity etc etc ] seems the big challenge will be at 7 o'clock depending on speed  I guess thats why he originally said electro mags at the bottom[and this part being tricky] and spoke of the device using some power to run [ self generating]   well   I can wait for the designer to show his design   Chet PS of course I could be completely wrong
Thanks Grandma
dirt diggler
Quote from: Bulbz on May 27, 2008, 08:22:26 AM
OMFG... Another debunker  :P.
Yes, I think we are going to see alot more of these guys showing up as the day draws near.  with more people trying to build the wheel, and even a couple who seem to have done it,  there are quite a few oil reps that are starting to get nervous about their future pensions ;D ;D ;D
on a side note, my wheel is progressing along well, but it is 4 feet in size, so it is taking some time to get all the bigger magnets/weight together.  will post video/pics as soon as something cool happens with it.
No, really, I love beating my head against this wall.......
Thaelin
Hi all:
   Well I guess I will make a small note on where I am now. Instead of trying to fight the word battles,
I decided to go underground and play. Well, I have a "one" tube wheel that can sustain rotation for
for a short while. New bearings are tight yet. Tube is not straight so has drag. But still does it.
   My slider has two 3/4X3/4" neos coupled to a 5/16" ss rod with 43 ss washers on each end. A coil
of 200' of #20 wire on each end to move it. All mechanical commutator on the back side of the
rotor to fire the coils. I had to add a small piece of wrestleing mat to cushion the magnets as they
did make quite a thump when hitting. Need to turn down the power to the coils a bit so as not to
make a bounce off the other end. KISS system. Proof of concept done and works!
   Off to find a suitable wheel now. This one will have the same setup but more tubes for a better
torque value at the shaft.
   This will be the exxcomm version with the coils on the tubes.
                    Next, the standard build when its published.
thaelin
mscoffman
redriderno22,
I just saw the video. I would love to see it in action though. (FIX THE AXLE!).
Yes redriderno22 I was very impressed with your build. One way to fix that axle is to substitute a VHS recorder rotary
read/write head capstan mechanism for it. It has a much stronger bearing and turns freely with very long run-down times.
It will need special mounting as the mechanism sits on an ramp angle. Please do this, because I'm afraid Archer is going
towards too much complexity in his. If this is to work, the simple wheel must turn by itself if it is gravitation and magnetic
metric dimensional forces that are doing the deed. Showing this simple unloaded mechanism on you-tube should be the
everyones first priority right now.
One thing to think about is that Archer's wheel seems to use the generator to produce a higher voltage, actually
220VAC in Australia, current. This would make it possible to do much more pulse shaping to the magfield  pulse
"to get in and do it's thing then get out" on the rods without affecting the momentum of the wheel very much".
The problem is that there are about 12 different environmental energy fields that one can tap into to provide 'fake'
overunity but that have environmental effects when one does them. I'm afraid of the ninety five percent efficient
Wheel with environmental overunity filled in, to make up in a very complex but self running balance of system.
This will make it difficult to discredit this system in a timely fashion, if it needs discrediting.
On the other hand, an unloaded overbalanced wheel operating and shown on you-tube would greatly allay my
concerns and I could support Archer's build like 100%. If this thing really does work then it's obviously very important.
It's like getting the keys to Fort Knox handed to you and someone saying; "you, get that yellow stuff out of here!".
You still have to move it though. Remember, many millions of people have never seen a credible reproducable
overunity machine operating...You can be the first to show that to them.
S: MarkSCoffman
