Roll on the 20th June
0 Members and 55 Guests are viewing this topic.
CLaNZeR
Hi Matt
The end of each Brass Rod is drilled tapped out with a 3mm thread, this means I can add extra length by screwing extra pieces in, or I can add small 3mm threaded Rod which will let me add weights either side of the magnets I attach. It also lets me attach different size magnets.
So not so restricted  ;)
Cheers
Sean.
Quote from: redriderno22 on May 26, 2008, 06:07:36 PM
ClAnZeR or sean
how ?
umm yours looks good, very good
but?
where are your mags going to be?
and your weights need to be beyond the mags.
hope this helps
matt
http://www.overunity.org.uk
I'm going to fish for a big favor here. I have a design that's similar to this one but uses gravity. Now what I would like to ask is if some of the builders here are wanting to experiment with this a bit along with archers idea. In #2 all you need extra is probably a relay,a solenoid coil, and a battery (amperage depending on the mass of the rod ). So far I just want to confirm that the wheel will keep rotating by pushing it at the right time. Later electricity generated by the wheel can be used partially for the electro magnet.
This will be a big favour indeed and the reward might be a potential working wheel  ;D.
http://www.overunity.com/index.php/topic,4769.msg100143.html#msg100143
dirt diggler
Quote from: broli on May 27, 2008, 03:10:17 PM
Ummmmm, this wheel is a gravity wheel, that uses either permanent or electro magnets to shift the weight to one side.  so I not sure what is different?  just the number of arms??
No, really, I love beating my head against this wall.......
Rusty_Springs
Quote from: Thaelin on May 27, 2008, 01:13:43 PM
Hi all:
   Well I guess I will make a small note on where I am now. Instead of trying to fight the word battles,
I decided to go underground and play. Well, I have a "one" tube wheel that can sustain rotation for
for a short while. New bearings are tight yet. Tube is not straight so has drag. But still does it.
   My slider has two 3/4X3/4" neos coupled to a 5/16" ss rod with 43 ss washers on each end. A coil
of 200' of #20 wire on each end to move it. All mechanical commutator on the back side of the
rotor to fire the coils. I had to add a small piece of wrestleing mat to cushion the magnets as they
did make quite a thump when hitting. Need to turn down the power to the coils a bit so as not to
make a bounce off the other end. KISS system. Proof of concept done and works!
   Off to find a suitable wheel now. This one will have the same setup but more tubes for a better
torque value at the shaft.
   This will be the exxcomm version with the coils on the tubes.
                    Next, the standard build when its published.
thaelin
Hi All
Ofcause it works with an electromagnet no one said it wouldn't work with an electromagnet but is it OU, I made a one pulse electromagnetic motor it used the iron core to attract overlapping magnets around then turned on the electromagnet to cross a small air gap, one quick pulse each cycle but it wasn't OU cuz I couldn't get the energy back for that small one pulse, maybe someone that knows more about electricity then me could work out a way to get it back, I couldn't, I know very little about electricity but I do know that a magnet crossing copper wire causes a current to flow and a magnetic field which reacts with the moving  magnet as it crosses, I thought alot of Archers followers would have know that to and pulled him aside to tell him.
I have pointed out why it will not work with permanent magnet as for an electromagnet I don't know if it will be OU thats yet to be seen and if it is then good work Archer but I can't see where you get the energy back to make it OU.
Two things if I didn't beleave you could get OU and worked for oil companies why have I posted ideas to help get OU's and two oil companies will not go out of bussiness because oil is used for more then just fuel one that they would get alot of bussiness form comes to mind and thats plastic and if an OU works you would need alot of plastic for all those new OU machines.
Take Care All
Graham
PS heres where you can see a video of that one pulse motor I talked about its called GemMotor
http://www.fdp.nu/shared/manager.asp?d=files\Graham%20Clarke\Gem%20motor\
Thaelin
@ Rusty
   Of course you can make such a small motor spin around with just a small pulse. Bedini motors do it well. See that thread on how to recapture it back. As for that type of motor having any kind of shaft power, sorry not there.
   Here you have a short pulse and then gravity takes the weight down for you. You will get much more power that way than by the pulse motor. More weight on the arms means more torque at the shaft. Why not lets see if the gem motor can turn a 95 amp alternator.
   It will all come out in three weeks. Get ready to build, I am.
   The best part, if I can only muster up enough to run an inverter to say 1500watts, its 1500 more than I had to begin with. Best part, its free after you save the initial investment. Only takes 500watts to run my whole computer system.
thaelin
