Thanks to ALL for your help!!
experiment show the posibility of building a gravity drive from a gyro
Started by raaaid, August 26, 2005, 08:29:37 AM
raaaid
the experiment is simple you wind a gyroscope and let it spin first precessing and second not precessing
the odd thing is that it lasts the same precessing than not precessing, this means that is gravity what produces the  energy that causes precession or that precession is a movement that requires no energy
now the idea is simple take a gyro and let it precess, friction will stop the gyro with time
but remember that precession consumes no energy from the gyro momentum? just cranck the spinning and the precession of the gyro in such a way that they are geared together so if it spins 1000 times for each turn of precession you gear it that way, 1000 to 1
now precession is feeding the gyro and gravity is feeding precession
i think its very simple and obvious once you take into account that precession is produced by gravity and manifested as an horizontal force and therefore a usable force
you are welcome to try my idea but dont patent it unless you want to get into trouble in the case it worked
triffid
I experimented with gyroscopes in the early 1990's and believe a space drive can be built from them.Triffid
triffid
About the same time I read an article about an australian inventor who had made one from gyroscopes
and had it floating about 4 inches off the table. Never heard anymore about it.Triffid
spacetrax
Hi Raaaid,
nice idea, can you make a sketch for it? Do you want to use it as an OU device?
Thanks!
Quote from: raaaid on August 26, 2005, 08:29:37 AM
