Audio amp+hydro gen cell?
Started by Dr.Greenthumb, April 25, 2008, 07:39:35 PM
vdubdipr
just make sure you dont draw too much current out of the amp!!  use an anl fuse inline on the power cord lower that the total of all fuses on the amplifier itself, i tried to hook up my cell to the wall outlet today... poped the circuit breaker right away even with the electolyte diluted way down..........3 times haha, just be real careful you know why...  cross all fingers and toes, and cheack your warranty status on the amp, if you got a good feeling roll the dice, but you might not even make that much power cuz the amp varies in power output by the ohm load or total impedance, so if your cell has a high resistance then even if its a 1000 watt amp at 2 ohms @ 6 ohms it will only make 250 watts know what i mean? of course you do... if your into compititions, good to hear you got internal speakers/tweeters to back up the bass i hate it when you get in someones car and you cant even hear music,just bass you know... ive always been partial to aidiobahn myself, i had 3 12inch sound q aluminum cones, with a flame q 2000 watt rms @ 1 ohm and then ibut in a rca line amp booster to 10 volts so i had about 2200 rms, along with a  old school ads 6 channel with 2 tweets and top of the line pioneer speekers, that was my favorite stereo, after i blew my 2 boston acoustic pros, then i got big into autotek amps and FI subs man FI subs are probubly the best thing out there right now, there NUTS.    peace
thats just what i think...
Dr.Greenthumb
yeah its a no go. The first time i hooked it up the power cord started to get a little hot and you could hear the 8000 hz tone i was putting into it! odd. tried a couple more times after that and it would just turn the amp off. im guessing it would need a full connection to actually work. Maybe if i hooked up a speaker to it as well as the cell it might work? something to try tonight.
vdubdipr
if it was getting a lil hot it was probubly drawing too much current, although amps tend to get hot on there own, when i plugged m shit into the wall just before the cuircut breaker pooped the socket was buzzing alot and the loudest ive ever hear a socket buzz... maybe just use the tiniest amount of electolyte and wire the speaker in series to add ohms , so theres less worry of blowing the amplifier..
Dr.Greenthumb
I forgot to mention I had the amp hooked up to the cell bridged (L neg to R pos) and didn't try it the other way. I could give that a go too. I spent most of my time yesterday cleaning the cell and trying to put spacer in it and lining it up. I think I'm going to head down to the steel place and ask them how much a sheet would be.And maybe have them cut it for me.
canada765
Ok, just an idea but here it goes,
For a simple idea to test how much sound resonance plays into this HH0 process why not do some simple experiments like take a glass beaker of water and mount small speakers on the outside. The glass should conduct the sound to the water inside fairly well. Inside the beaker you have some simple electrodes. Why not use razor blades? Should be fairly high grade stainless steel.... Put one over the other and separate by some 2-way tape, (or glue or whatever) say enough to get a 1 mm space, it's easy to change and add more if desired but start simple by having just one anode and cathode... Start by tuning different audio frequencies , either through a signal generator or a software program. Combine this with the electrolysis process and see what happens when you change the audio frequencies. Worth a try perhaps? I don't think a kicker amp is needed, what is needed is more finesse. Without applying any power to the electrodes it should be possible to see what frequencies effect the water and then try using either regular or pulsed D.C electrolysis and see if there is any performance increase when you notice any sound/water resonance. My guess is there should be. Anyone else want to experiment with this?
