David Bowling's Continuous Charging Device
Started by sterlinga, April 30, 2008, 10:56:29 PM
ramset
Dave
I know what you are seeing is genuine , having spoken with you and understanding the resources
you have at your disposal as well as your own very capable abilities ..to me it is self evident .
  That being said the real crux has always been "where is the energy coming from" ??
there are few options for energy to enter the system , and this means its really Simple
and That makes it quite exciting indeed .
Now you add Matts Motor to the Mix and His comment on the Benitez [spelling?] patent and its brutal
simplicity ....
Dave I sincerely hope the world brings you much long life and happiness ,and I hope that new little
Granddaughter can have a better life for it .
this is all very very exciting indeed !!
respectfully
Chet K
PS
Carlos Benitez patent attached
http://www.tuks.nl/pdf/Patents/Benitez/Carlos%20Benitez.pdf
PPS
Quite certain Tinman meant Specific gravity ,he's been burning the candle in 4 time zones with all the associated sleeplessness
and slips of mind .
Thanks Grandma
DreamThinkBuild
Hi Dave,
I've never tested these claims but thought you might find the following interesting and in line with your work.
There is one patent, JP2013-046437, of using one battery, one motor and two generators. His original system was using three batteries in a similar configuration before switching to a mechanical system.
Original battery system:
QuoteIt is important to take out electrical energy from a power supply efficiently in view of energy problems. Then, the inventor proposed the feeder system which can maintain supply to electric load over a long period of time as a Patent document 1.
The power supply section by which, as for the feeder system of the description to this Patent document 1, a DC motor and two or more cells were provided in parallel, The series connection of the direct current generator which drives a DC motor as a driving source, and the changeover switch in which the cell energized among each cell is switched for every time required is carried out, and the electrical energy generated with a direct current generator is used for charge of a power supply section, the drive of a DC motor, and the electric supply to electric load.
Mechanical System:
QuoteThe current amplification equipment of the present invention is provided with a DC motor, and the 1st rotated with the aforementioned DC motor and a second direct current generator, The positive electrode on the DC-power-supply side is connected to the positive electrode of the aforementioned DC motor, and to the positive electrode of the above-mentioned first direct current generator, The anode of the aforementioned DC motor is connected and to the anode of the above-mentioned first direct current generator, The anode used as the ground on the aforementioned DC-power-supply side is connected, and to the positive electrode of the above-mentioned second direct current generator, The positive electrode of the aforementioned DC motor was connected, the positive electrode of the above-mentioned first direct current generator was connected to the anode of the above-mentioned second direct current generator, and the positive electrode of the above-mentioned second direct current generator and the anode of the aforementioned DC power supply were considered as the output.
[0007]
According to the current amplification equipment of the present invention, it can rotate, when the current from DC power supply flows into a DC motor, and it can be made to generate electricity with a first direct current generator and second direct current generator. From a second direct current generator, the direct output of the output current can be carried out via the second direct current generator from a first direct current generator by this power generation. Therefore, since the 1st and the output current from a second direct current generator are acquired with the current from DC power supply as output current, output current can be efficiently amplified to the current from DC power supply.
[0008]
It is desirable to provide resistance linked to the positive electrode of the above-mentioned second direct current generator and the positive electrode of the above-mentioned first direct current generator. It is desirable to provide resistance linked to the positive electrode of the above-mentioned second direct current generator and the anode of the above-mentioned first direct current generator.
[0009]
The aforementioned DC motor, the above-mentioned first direct current generator, and the above-mentioned second direct current generator are that each axis of rotation is turned in the direction, and the aforementioned DC motor rotates via an endless belt, and it is desirable to go around to the same hand of cut.
bellerian1
Hello David,
My name is Gene, I know Luther, a fellow whom at one point was working with you on the 3bgs setup.   I'm familiar with what I've come to call the RPS configurations of sources... relative potential sources.   I like that you found you could run the inverter between two +'s so long as the volt offset was retained thru the configuration of the parallel stack against the series stack of batteries.   Did you note you could do the same using the two -'s as well?
Did you know you can use transistors of whatever type with the RPS as a source so long as you maintain the polar bias's properly with relation to the leads on the semiconductor?   I did that with a bedini SG setup, automatically doubles the batteries being charged when theres a parallel stack to recover all the spent energy on the input side... ;)
Anyways keep it up man, no idea if you still work with Luther but he was a good guy.   Hope you guys find some offset like maybe some solar panels to offset the discharge from the series stack and size that properly to keep the series stack being fully charged up during the day and maybe use a second set of solar panels as the series stacks potential during the daylight hours.   Then you'd set the system to run from the series stack at the end of the daylights hours on the solar panels and overnight, then the next day you'd put the series bank back on charge, and use the solar panels output as the series stack for as long as theres daylight, then repeat the cycle...    Might then have a system that works between the two extremes of being charged/discharged on the daily periodicity.
From my end I've built a 50,000vdc RPS setup... I'm going at it the "sync" route.  Will eventually see if anything pans out...
Take care man,
Gene/Bellerian1
Quote from: Dbowling on June 07, 2016, 10:34:42 AM
Brad,
You ask a question and when I answer it, you tell me I am wrong.
This is why I will no longer waste my time coming here.
You did not want my answer. All you wanted was an opportunity to tell me I am wrong.
Well, you got it, but after today you won't get any more chances.
I will not waste my time arguing with someone who has a closed mind because of what they "believe" and will not take the time to build the system and do the PROPER testing you are so committed to but have obviously NOT done.
I have spent 8 years of my life working with potential differences.
I have spent thousands of dollars and run thousands of tests.
I have ruined a hundred batteries running batteries in circuits that did not provide enough energy across the potential to properly charge the low side. Many of those are in my "dead battery bank", but some have been turned in for core charges.
I have paid for lab time at the university to use their battery analyzer to do controlled measurements of inputs and outputs. Tests that are far more accurate than a "pacific gravity" test. And by the way, it is a "SPECIFIC" gravity test, not "pacific". I have done that too. Have YOU? I didn't think so.
I know what I know.
Have you actually built this circuit and put a scope on it? Because when you tune the boost module, you can select the voltage that hits the battery on the other side of the load and it is hit with 14.5 volts. Period. The motor will actually put out 14.5 out the other side, or MORE,  WITHOUT a boost converter in the mix because it acts as a generator at the same time it is running as a motor, and run between the potentials that generated voltage comes out in a way that does NOT happen in a normal situation. But that is ANOTHER issue. What the boost module does is maintain the voltage at 14.5 to the charge battery for a much longer period of time, when the TRUE voltage across the potential has dropped to as low as 7 or 8 volts because the charge battery has come UP while the primaries have gone DOWN. Anyone who has EVER run this circuit for an extended length of time can tell you that they will get extended run times out of the batteries. Will it run forever? NO! I am not saying it will. I am saying that as PART OF A SYSTEM, it gets you where you want to be.
You can choose to BELIEVE what you WANT to BELIEVE and I will choose to KNOW what I KNOW. Yes, I AM encouraging people to build the ENTIRE system I spoke of above, because I know that AS A SYSTEM it works. I have it sitting on the bench in my shop and it produces free energy. Is the specific circuit BY ITSELF COP>1?  Yes it is. But that is NOT enough to get people where they want to be. I am NOT saying that it is. You only recover about 80-90% of what is run through the system, but do you have any idea what that works out to when coupled with an efficient generator?
But you win Brad.
I will go away now
Another victory for those with a closed mind
And do you know WHY I am giving in so easy? Because YOU are not important, and because this BASIC information that I have tried so hard to share is just the BEGINNING of a long path I went down to find the answers I was looking for. We have moved beyond this. Way beyond. It was our hope that this BASIC information would start others down the correct path, but if you want to be the road block to that, be my guest. My conscience is clear. I have tried MANY TIMES to get the information out there and that is all anyone can do. Best of luck to ya mate.
Dbowling
With this circuit, I do not believe there is ANY energy entering the system from the outside. Benitez and Tesla BOTH developed systems based on extracting energy from the transfer of power from a higher potential to a lower potential. It is NOT rocket science. It is very simple and straightforward. The issue with it has ALWAYS been the switching, and its COST (because the batteries MUST move to different positions within the circuit) and controlling the stability of that potential difference which (in this system for example) starts at 12 volts* and goes down as the primaries discharge and the secondary batteries charge up.. The BOOST CIRCUIT is something neither Benitez NOR Tesla had, and it regulates that potential in a way they could only DREAM about.
But despite all our modern advancements, the only way to scale this up to run a house is to purchase a mountain of batteries. Not a happy thought.
What it WILL do, as part of a system, is run the heck out of a small motor which can be used to run a generator that puts out MANY TIMES what is needed to maintain the system. The output of that generator can be used as the high side of an even BIGGER potential based system to run a bigger motor and generator and the output of that generator as the high side of a BIGGER system.......until you are running the country on the five batteries on the bench in my garage. If you build it on a very SMALL SCALE and then try to build a potential based system to run off the generated power, you would see what I mean. I NEVER in my life thought I would be worried about producing TOO MUCH power from a system, but that's where this goes rather quickly. And high voltages make me very, very nervous.
But most importantly, and I cannot stress this enough, this is NOTHING but the basics of this technology. It sets you on the right path. It teaches you HOW to use energy without using it up. And when you master THAT.....!!!
*For purposes of discussion it is assumed that each battery has exactly 12 volts in it. This is not a reality as you all well know.
PS. I KNOW Tinman knows that it is "specific gravity." I have read a lot of his stuff and he's a pretty sharp guy. I just couldn't help myself. LOL
SeaMonkey
Quote from: DBowling
I am wrong.
chances.
done.
This sort of attitude is problematic.  It is indicative of a
"builder" who does not fully understand what his device
is doing and exhibits excessive emotional attachment to
beliefs which may be in error.
What TinMan explained is truth that is easily verified with
test instruments.  He has explained how your description
of "running for free" is not quite true.
If there is in fact excess energy to be accounted for in your
device then you must be better prepared to explain it in a
technically correct fashion and to verify it with accurate
measurement tools.
Voltage measurements of Lead Acid Batteries can be very
deceptive and never accurately indicate a quantity of stored
energy.
Those who find flaws in your explanations may be speaking
truth.  Pointing those flaws out does not necessarily indicate a
closed mind.  Beginners in Electrical Research often make
that same mistake by emotionally defensive attitudes.
We never like to consider the possibility that our thoughts may
be wrong - but quite often they are.  Then we must choose to
either find truth or continue with false beliefs.  Letting go of
emotional attachments is never easy and can be quite painful.
Do you want a following of ignorant builders who believe your
every utterance; or do you want technically competent observers
to offer constructive criticisms?  Are you really seeking truth or
are you caught up in a fantasy?
Now, if true, that is quite an accomplishment.
The challenge is to offer evidence that it is true in
a manner that is persuasive and verifiable.
You've already admitted that you've spent large sums
in support of your research.  How many are prepared
to make the same sort of investment in time and
financial resources?  Without showing a practical
application which could be immediately put to use
in powering a home or reducing reliance upon the
grid?  Can you comprehend why those who have
chosen to replicate are small in number?
