New Unified theory !
Started by hartiberlin, September 01, 2005, 06:24:58 PM
hartiberlin
Alex Kaivarainen wrote:
Dear All,
The improved version of my Unified theory, including deeper analysis of suggested earlier dynamic mechanism of duality, gravitation and antigravitation, mechanism of overunity and extraction of the excessive energy from Bivacuum is just placed to the arXiv:
http://arxiv.org/abs/physics/0003001
Best wishes.
Alex Kaivarainen
www.karelia.ru/~alexk
Kator01
Hey,
in trying to visit this Link : Access Denied !!!
Kator01
ring_theory
Great forum I find it educational as most of it is right on the money i can tell that much research has gone into the subject of over-unity. 8)
However in the quantum world mass is mia. IMHO we have to recognize unity and achieve it via a mechanism or process before we can even concider overunity.
From what i have seen this far, if you made an effort to unify the various technologies highlighted here and applied them to one mechanism you would find that a unified theory would involve so much more than just overunity.
what is known to date of relativity is just a small part of what is really relative in physics that we havn't discovered yet. Through 20 years of research and development of a mechanism utilizing kinetic energy in a frictionless invironment, I have reached a level of understanding that shows everything in the universe is unified by one simple motion. Unity is defined as "<in a table of natural sines the radius of the circle is regarded as unity>" if this is the case than simply a ring (toroid) at rest is unity. you have to admit that faraday's works show a definate oddity about rings when a magnetic field is introduced. among other things a ring is essentially the perfect wave form implicating wave harmonics.
ring
Not complete or perfect but in the process of building it. I've been trying to find proper componants for many years they simply don't exist "yet".
This is a low budget operation so i cannot afford to pay for retooling to get "as designed" componants.
Above image is of the fields that the ring consists of. the green film is magnetic reactive and shows the fields present. however their are extra flux fields that are imposed on as they enter the drive coils and will flux back out to excite the induction coils. 4 induction coils will be wound around the prototype and target rpm's are 50,000 that's in comparison to a faraday flashlight shaken 8,000,000 times a minute. This mechanism Is faraday's principles RUN AMUK. Two of faradays principles are used in this invention. Electro Motive Force and Electromagnetic induction. In fact had faraday continued his works. I believe he would have discovered this mechanism himself. The jumping ring was some of his works. Which i believe implicates the event horizon and all of it's by-products.
Above image is of the magnets superglued to sliced o-ring sections to space the magnets appropreatly arranged in a ring. Note the fields of the actual magnets spaced as such create the extra flux fields apparent in the top image. Also note that the fields are closer at the inner radius of the ring of fields and farther from eachother at the outer radius of the ring of fields
Above image was me toying with infinity. I simply twisted the ring of magnets and it represented infinity.
The image above is the ring of magnets (toroid armature) nearly half encased in epoxy. epoxy side up. I still have to finish putting epoxy on this componant and form it closer to a toroidal form. A lathe would be a great help here but that's not in the budget. looks like a wood jig, a drill, and a dremel will be the method of getting an approximation of a toroid form with this prototype. perfection or acceptable tolerances are not critical for this prototype it is just to show that the mechanism will operate as designed for peer review.
The above image is the Toroid armature with ring of magnets nearly half encased magnets side up. I had hoped that the epoxy would have been bubble free so it would be transparent. however it makes no difference.
The above image is of a drawing i made of a part of the spool componant. it is double sliced and represented linear as all i have is a ruler and my curves freehand suck. The gear is just that it is a way of rotating the spool to wind the coils needed by design. it is around the toroid armature but not connected as the toroid armature is supported by the drive coil and will be caged in the center of the spool/toroid chamber.
The above drawing is of the spool in this prototype it represents 1/4 of the spool the ends represent the gears on the spool/chamber. It is also represented linear but in application will be a toroidal form around the toroid armature. the spool/chamber will be vacuume sealed in production models but for the prototype it is still an option i am exploring.  However the coil placement is simular to what it will actually be.
I'm in the process of making this prototype with very little capitol and i have to make small changes to the design due to the parts are just not manufactured as needed. I concider that a blessing as it indicates that NOTHING like it has been done before.
I'm allways ready to explain any aspect of this mechanism. If you don't understand anything or would like more details feel free to contact me.
Terry L Hewett Sr 8)
ring_theory@yahoo.com
http://www.terrylhewettsr.rackhost.net/
lanca III
It is very interesting to hear such an idea because there could be a concept to
get an experimental "status quo":
the Felix Wuerth Fluid Generator and the introducement of the Torribio Bellocq Analogon in this system,centrifugal and peripedal Orientation Effect:
+ 900% or -90%
Kator01
Folks,
forget the W?rth-System. No solid physcal background. He is feeding on private investment-money since years. i observe at least this since
5 yeards. No valid results.
Very sad. People loose money.
Kator
