For Stefan: About the Bedini Motor/Generator
Started by Magnethos, May 11, 2008, 02:35:54 PM
Magnethos
About a Bedini Motor/Generator
This topic tries to explain how works a possible (?) free energy device that I show in the next video on youtube:
http://www.youtube.com/watch?v=ai7aX6OK5hw
As you know, the bedini motor is a pulsed motor. To understand better my schematics you can see at the next picture:
Now, I?m going to show one alternator based in a wind turbine design:
Here you can see some videos of wind turbines:
100 Watt
Homemade DIY Wind generator 100 watts http://www.youtube.com/watch?v=UNlf54eUBCg
100w 12v wind generator / turbine Alluminium blades http://www.youtube.com/watch?v=ozpzJO-OPDU
Cheap Simple DIY Wind Turbine http://www.youtube.com/watch?v=FUL0vggLSKI
600 Watt
http://www.youtube.com/watch?v=eqdsX5wxhNw&feature=related
1140Watt
Prototype wind turbine (autofurling). http://www.youtube.com/watch?v=ezjHFj6vXkQ
1.5kW
Wind Turbine 1,5 KW http://www.youtube.com/watch?v=DwU8PX2tw0I
You can find more videos showing from 1 Watt to some KWatt. More Big = More Watt
Note: I only mean the alternator, not the complete wind turbine. I know there are other alternator designs like the car alternator. But I use this because is the perfect one to merge with the bedini motor. The main idea is use the bedini motor to move the alternator instead the wind and the blades that a wind turbine generator uses.
If you merge the bedini motor with the wind turbine alternator, you have this:
You can run a Bedini motor with some mAmps and some volts. An alternator can put output 100 Watt as minimum. I have seen some guys in videos that says that with a wind turbine you can get 1kW or more.
So, using a medium size Bedini motor, you need some volts and few mAmps to run.
To get more output energy, you can use two stators instead of one:
If you want to get a perpetual device, you can run the motor from the first battery while the second battery is charging. When the first battery is discharged, you run the motor from the second battery. The batteries are charged using the energy from the alternator.
I have just find a video that seems to show a similar idea that I?m trying to explain. You must to build a much better device if you want to get good results and get an overunity.
http://www.youtube.com/watch?v=qt8nXzPKI0w
hartiberlin
Hi,
thanks for the explanation.
The only problem still is the Lenz law.
If you draw current from the generator coils,
you will drag down the motion of the Bedini wheel
and thus you will not be able to power the Bedini wheel
just with a few milliamps only...
Did you already try this ?
It would only work, if you invent a NO LENZ effect generator.
Regards, Stefan.
Magnethos
I haven?t build the device. But I think that the Bedini motor will run in less than 100 Watt... sure. But I will think about that you say to me. But the only way to prove if the device would work or not, it?s obviously building one device.
Thanks
hartiberlin
Yes, you can run a Bedini wheel
surely in idle mode,
when there is no drag on it, like a flywheel
with less than 1 Watts.
YOu just have to overcome the air friction and
the bearing frictions power losses..
But if you slow it down via the drag from the flowing currents
from an attached generator, you would probably a lot more input power
or it could not take the drag torque and come to a stillstand, when all
the stored flywheel energy is used up...
Just try it...
nightlife
hartiberlin, I have seen some bedini motors use no more amps when a load is applied then they do when no load is applied like in this following video link.
http://www.youtube.com/watch?v=3G5r3CSLteY
