FREE ENERGY USING MAGNETS
Started by nightlife, May 13, 2008, 11:27:44 AM
jeffc
Question:
Does anyone know if a horseshoe or U shaped magnet can lift more weight using both ends together than a similar bar magnet using only one end?
I don't have any horseshoe or U shaped magnets to test with, only bar and cylinder so I cannot test this concept.
Regards,
jeffc
Koen1
Seems to me that two bar or cylindrical magnets connected via
a piece of ferromagnetic material such as 'soft' iron should result
in a sort of U-shaped magnet with two poles on one side,
and you should be able to test if that 2-pole end can lift more
weight than the 1-pole end of the same two cylinder or bar magnets
connected to form one double length bar or cylinder...
nightlife
I just finished my testing on both, permanent magnets as well as a electromagnet. Both results confirmed my assumption to be true.
Both poles from both the electromagnet and the permanent magnet attracted and repelled equally regardless if one pole was loaded or not.
Are there any other concerns I should check in to before going any further?
Koen1
I don't see any at the moment...
So it's true then?
If you only use one pole of an electromagnet to push or pull the rotor,
you're actually wasting 50% of the energy?
That's quite funky...
And neither Bearden or Bedini noticed this?
It almost sounds impossible eh... But hey, that's what they said about
heavier than air flight too, and two funny bicycle builders made that work...
So that shouldn't stop you from trying your 2-pole setup! ;D
nightlife
Koen1,
QuoteSo it's true then?
Based on my testing it's true. When I used a permanent magnet, I placed a iron object to the point of attractions start and then I placed a identical iron object on the opposite side at the point of its attractions start and then I confirmed that the other was still at the attraction start and then I measured the distance between the two and I found them to be exact. I then did the test using the repelling effect and ended up with the same results.
I then Tested a electromagnet the same way and I ended up with the same results.
QuoteAnd neither Bearden or Bedini noticed this?
I can't say they did or didn't but I have yet to see a motor built and or designed using this design.
QuoteIt almost sounds impossible
That is true and that is why I tested what was questioned just to make sure. There may be a design out there like this and it is just being hid from us. Heck, you never know these days and I can't believe that my self being a POS 9th grade drop out could figure this out and no else has. Some one else must have figured this out other then me.
