FREE ENERGY USING MAGNETS
Started by nightlife, May 13, 2008, 11:27:44 AM
petersone
Hi  Gyula
I don't think I'm understanding even the very basics of this,shame on me!!
How, if the output coil is not connected to the input coil when pulsed,how can anything be taken from the output coil?
That aside,going back to the motor,with an "ou"pulse,how about if instead of a rotor,there is an iron piece being drawn into towards the magnet,and released,which is inturn connected to a magnet moving in a coil,there is no electrical connection between the two coils.
happy hunting
peter
gyulasun
Hi Peter,
Sorry.  All I can suggest first try studying the MEG principle which is basically flux steering in a closed soft iron core from one leg/column to the opposite leg/column. See this link: http://jnaudin.free.fr/meg/megdsqth.htm  but do not be overwhelmed by its ou numbers because NOBODY has showed it in practice yet.  Only I mean the principle you can understand.
Now if you got the principle the answer to your first question (How, if the output coil is not connected to the input coil when pulsed,how can anything be taken from the output coil?) is that there is a direct flux connection between the input and output coils, for they are on the SAME core! This is the same flux connection as in a conventional transformer and this is a drawback here and this is where the a correctly timed output switch could separate the EFFECT of the common flux path so that the output load would not reflect back to the input, which otherwise surely does.
Well I think this sounds a better solution for utilizing the benefit of adding two fluxes together so I suggest going for it,  only practical tests can give correct answers.
Just peep into Steven latest answer on Hildebrand thread, very instructive: http://www.overunity.com/index.php/topic,2386.msg103954.html#msg103954
rgds,  Gyula
eddy
HI GYULA AND FOLKS,
              FIRSTLY THANKS GYULA FOR THE GUIDANCE RE. MY NEW MEMBERSHIP.
              I FIND THE TECHNICAL DETAILS DISCUSSED OUT OF MY DEPTH NOT BEING AN ELECTRICAL ENGINEER BUT I'D LIKE TO POINT OUT THAT THERE IS FREE INFORMATION AVAILABLE FROM THE THE SURGE.COM GROUP OF HOW TO BUILD A WORKING MAGNETIC MOTOR,THE ONLY PROBLEM I SEE (IF IT WORKS AS SUGGESTED ) IS THE FUNDING AND PRODUCTION DUE TO THE ECONOMIC CLIMATE AND THE VESTED INTERESTS IN THE CONTROLLING BODIES CONCERNED.
             I WILL BE EAGER TO HEAR OF ANY REPORTS RE. THE MAGNETIC MOTOR DISPLAYED WITH SURGE.COM . IF IT PROVES TO BE FUNCTIONAL IN PRINCIPLE THEN ALL WE NEED IS TO FIND AN ENGINEERING COMPANY WILLING TO TAKE ON THE CONTRACT.
            I HAVE NO INTEREST IN MAKING MONEY FROM THIS TECHNOLOGY, I FEEL THESE FREE ENERGY DEVICES SHOULD BE AVILABLE TO THE WORLD IN GENERAL TO SOLVE AN ENDLESS LIST OF GLOBAL PROBLEMS.
            FINALLY HAS ANYBODY GOT ANY LINKS WITH THE DR.GREER'S DISCLOSURE PROJECT AND THE WEALTH OF INFORMATION AVAILABLE THERE.
            ALL GOOD WISHES FOR OUR SUCCESS, KIND REGARDS EDDY
gyulasun
Hi Eddy,
It was nightlife who kindy guided you, not me  but thanks for the kind words anyway.
I cannot seem to find surge.com  could you give a correct link to it?
Thanks,  Gyula
eddy
HI GYULA,
       TROY REED DIED LAST YEAR BUT HIS MAGNETIC MOTOR CAN BE VIEWED ON THE LINK BELOW. DENNIS WEAVER THE ACTOR WAS FUNDING HIS PROJECTS;
       Directory:Surge Motor Technology by Troy Reed - PESWiki ;
        THERE IS NOW A GROUP ATTACHED TO THIS LINK WHO ARE AVAILABLE TO SUPPLY TECHNICAL INFO. THEY ARE UNABLE TO PRODUCE ANY FREE ENERGY DEVICES.
        I HOPE Y'ALL FIND THIS INFO. USEFUL.
        KIND REGARDS EDDY
